Hello,
so I finally recieved 10ohm 1w 1% resistor and proceed with the measuring.
I measured without amp (directly from sound card) and with amp
And I got totaly different curves and T/S parametres.
No amp:
With amp (30w EQ to flat and volume at 15/30 -at this volume I get speaker about equaly loud as with only sound card):
I`m totally lost right now.
Should I use measurement measured directy from soundcard?
Thank you for help
No amp:
Thank you for help
Seas uses a 2 Vrms signal, as measured at the drivers terminals. I suggest you try the same level with your amplifier.
DATASHEETS
DATASHEETS
Well I can`t do that. Max input of Line In on my sound card is 1.1V, 0.2V for mic.Seas uses a 2 Vrms signal, as measured at the drivers terminals. I suggest you try the same level with your amplifier.
DATASHEETS
Hy,can you supply more details about the amp your using?
setting volume by ear is suspect.
you've got the resistor why can you use it to set the level?
I`m using Sony micro hi-fi component system, rated at 2x30w
I don`t understand what you mean by setting level with resistor.
i was suggesting using the resistor as a substitute for the speaker as a load so you can establish a 1 watt level for testing.
if your sound card's input is listed as 1.1v max setting a 1 watt level may be a problem.
what software are you using?
quick look at Sony micro components systems suggest they may not go low enough in frequency for what you want to do.
You could build this circuit if you want to measure at higher signal levels: http://www.artalabs.hr/AppNotes/AP1_MeasuringBox-Rev4Eng.pdfWell I can`t do that. Max input of Line In on my sound card is 1.1V, 0.2V for mic.
Remove all microphone related stuff if you don't need it (J3, R5, SW1). It works really well.
- Subwoofers
- Measuring T/S with audioTester amp or no amp
