Making subwoofer box and changing circle port to rectangle
Old 10th November 2017, 04:07 PM   #1
davidlevy129 is offline davidlevy129  United States
Default Making subwoofer box and changing circle port to rectangle
So I'm going to make a subwoofer box from the recommended sizes in my subwoofer Manuel and I wanted to change the dimensions to something more shallow but longer but of course keeping it the same recommended volume requirement. Would this mess with the performance if I change the dimensions but keep the same volume? And also I want to know can I convert the circular port dimensions into a rectangular dimension.
Old 10th November 2017, 05:33 PM   #2
Sonce is offline Sonce  Macedonia
If the volume is the same it is OK, but do not make very long and slim box - it will turn into a bad TL box, sort of.
Same area: 76mm (3") circle = 67.35 mm square.
Old 10th November 2017, 06:59 PM   #3
Think is offline Think  Netherlands
Yes, but using a rectangular port like a rond one will give more turbulance. So u need to make them bigger and then they will have to be longer. Integrating it in a corner is IMHO often a better idea if you want somehing else then round. Something like: The Lab12 PA Subwoofer Smack Down/Death Match
Old 15th November 2017, 07:31 PM   #4
It was a rectangular port
Old 16th November 2017, 01:46 AM   #5
Disregard my last comment but I also see there's different volumes of boxes you can do based on the sound tight versus recommended versus deep what is this mean? And what does it affect?
Old 16th November 2017, 05:51 AM   #6
GM is offline GM  United States
GM's Avatar
Well, in Pioneer 'speak', 'Tight' means high tuned, 'Deep' means low tuned and 'Optimum' is in the middle.
Around here, 'tight' means highly damped, so 'deep' would be the closest, though being mobile audio designs, all of them are severely under-damped, i.e. 'loose', ringing', 'boomy', or 'tight' according to Pioneer.
If perchance this is for HIFI/HT use, then none of them really apply.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th November 2017, 06:25 AM   #7
Sorry I don't understand your lingo can you elaborate. I am using this for home theater so what size would you recommend. And as far as making another box with different dimensions but the same volume. What can I use as far as a program or a calculator to help me keep the same volume but change the dimensions?Google SketchUp?
Old 17th November 2017, 07:02 PM   #8
GM's Avatar
Hmm, the only way I can break it down further is to provide measurement plots and somewhat educate you on Thiele-Small [T/S] filter theory, which is available on various DIY forums, folk's websites, so recommend researching it along with over & under-damped speaker responses if you're curious enough.
Which driver, there's [2] listed? The short answer for HT apps is a large, tapered transmission line [TQWT] or a tapped variant [TTL, TH].
I've seen a number of on-line box design calculators that's a lot simpler to use than SketchUp unless one is already using it, including one like you want, so probably more, but haven't saved any links.
GM
Old 20th November 2017, 12:53 AM   #9
GM
It's the 304r and what would be the big difference using those box types versus regular ported box
Making subwoofer box and changing circle port to rectangleHide this!Advertise here!
Changing bass reflex port diameter from 80mm to 75mm Niels K PA Systems 14 28th July 2016 01:18 PM
Subwoofer, making the correct port length? using 2 of the walls Toast_Master Subwoofers 6 11th June 2011 03:07 AM
Need help with making a port for a custom enclosure. the cobbler Construction Tips 2 16th May 2011 09:02 PM
Changing phase makes subwoofer rattle - why? bunshi Subwoofers 2 28th April 2010 06:00 AM
part circle port calculation jayam000 Subwoofers 2 27th February 2010 07:08 AM
