Impedance matching...
Old 4th November 2017, 10:13 PM   #1
diy1995 is offline diy1995
Default Impedance matching...
Hello,
I builded push-pull design woofer from two 30w 5.25inch woofers, but one is 4ohm and other is 8ohm.
It plays nice, but I ran into the problem that one gets more power than the other...
How can I solve this to deliver the same power to both speakers?
I think that I need to add a resistor (4ohm in series with 4ohm speaker?)
Thank you for help
Old 4th November 2017, 10:35 PM   #2
rayma is offline rayma  United States
There's no way to passively have both receive the same power other than with
an autotransformer for the 4R (which is impractical).
You'd have to use a separate power amplifier for each, and set the acoustical
volumes equal, with the input level control.
Old 4th November 2017, 11:00 PM   #3
Thats what I was afraid of. now I have to put another amp in my stuffed room :S
thank you for help
Old 4th November 2017, 11:02 PM   #4
Thats what I was afraid of. now I have to put another amp in my stuffed room.
It's not so bad, there are cheap class D amplifiers that should work fine for this used in pairs.
Old 4th November 2017, 11:06 PM   #5
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
It would be cheaper to buy a new woofer than buy a new amp.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 5th November 2017, 11:38 AM   #6
I know but I can use spare amp that I already have so thats no problem.
Old 5th November 2017, 06:07 PM   #7
I`m looking at cheap amp from aliexpress but I will ask for opinions in amplifiers section.
Impedance matching...Hide this!Advertise here!
Impedance matching Alkis Tubes / Valves 12 14th November 2012 12:35 PM
Impedance matching netster403 Solid State 4 11th July 2007 12:06 AM
Help with Impedance Matching mudihan Pass Labs 6 14th July 2006 10:35 AM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
Impedance Matching bryce66 Solid State 6 9th November 2001 09:02 AM
