Best replacement 10" drivers 0 each budget..
Old 26th October 2017, 05:44 PM   #1
compaddict is offline compaddict
Default Best replacement 10" drivers $250 each budget..
I have a total of four 3 cubic foot sealed enclosures that house two 10" drivers each. The current drivers are hand made and I don't have specifications for them. They were built for SQ. The enclosures are 1" thick and crazy strong.
I have two INuke 1000 for each array of two boxes and a MiniDSP feeding them. They sound pretty good now but I would like them to go a bit deeper and still be able to shake the house with a Basshead track or two.
I know that sub drivers have come a long way in the last few years and I am wondering if someone here has a recommendation for a driver that would really make a difference?
TIA,
Vince
Old 27th October 2017, 08:32 AM   #2
USRFobiwan is offline USRFobiwan
Horn Addict
USRFobiwan's Avatar
You can try boxsim or winIsd to add the dimensions of this enclosure an throw a few hundred drivers specs at them until you're satisfied, another way is to use DATS and measure the actual drivers and see if any available drivers have the same specs.
Either way you probably want to design a new enclosures with these drivers (if you measure them with DATS) or design new enclosures with new drivers.
Destroyed some nostalgia
For the love of Horns and glory of pressure waves.
Old 27th October 2017, 11:39 PM   #3
I will look into that.
Thank you.
Vince
Old 28th October 2017, 12:19 AM   #4
CharlieLaub is offline CharlieLaub  United States
Here are some other key things to consider:
1. how high in frequency do you need the subs to play? E.g. what crossover point will you use?
2. How important is max SPL, e.g. the sensitivity of the driver?
3. How important is frequency extension, e.g. how low the go before rolling off?
These things involve some tradeoffs. For example, if you get the longest stroke 10" sub it will be able to move a lot of air (on paper) but might need even more power than your iNuke amp (horribly overrated in terms of actual power output) can deliver. Such a sub may have high inductance, and so it may not be able to play much above 150Hz before rolling off. This varies from model to model, however.
If higher sensitivity is your goal, so the sub will play louder within its passband you would likely look for more of a high SQ woofer than a sub. You can still get good extension, but it is not one of those drivers with 20mm Xmax. Maybe 10-12mm, and since you have four of them it might be fine in terms of total output, and you might enjoy them more.
The suggestion by USRFobiwan to use a box modeler to model the response of potential drivers in your boxes is a very good one. I like to use Unibox for this purpose, because it's free and it allows me to model the rolloff due to v.c. inductance. You can download it from my software page via link in my sig. The only thing that is not obvious with this program is that the power you enter for multiple driver systems is the power applied to EACH driver, not to the series or parallel (or S-P) connection to all the drivers wired together. You can just model one driver and then add 6dB to get the SPL with four of them each driven by the same amount of power from a separate amp channel.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 28th October 2017, 03:20 AM   #5
Homework!
Thank you very much!
Vince
Old 28th October 2017, 07:02 AM   #6
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
Hi compadict
With 3 cu ft = 85 liter per box, I would for sure reccomend changing these to a vented design by installing some decent ports. I would think you can fit some that are long and large enough for a design with 2 tens.
Next I would, as suggested meassure the current drivers T/S parameters. I use Dayton DATS myselv, and it is really easy. Then figure if these can actually be usefull for a vented design fitting in your boxes, by use of WinISD sim tool.
Some will for sure say no, but I think you can get as "tight" bass response from a vented box as from a sealed (it's a bit of religion I think), but a vented box is by fare more efficinet in the low end, and with 6 10 inch drivers, you should quite surely be able to rattle your home.
I would try to go for a tuning of 25 Hz if the river box combination allows for it.
regards Baldin
Maybe post some pictures of the drivers and the boxes?
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 28th October 2017, 03:43 PM   #7
More homework!
25Hz would be perfect.
Old 28th October 2017, 09:02 PM   #8
JonBocani is offline JonBocani  Canada
TIA,
Vince
cut holes in your existing enclosures and use the drivers you already have, along with these:
Dayton Audio RSS265-PR 10" Aluminum Cone Passive Radiator
(if enclosure large enough, use the 15'' version: 1 in each enclosure should suffice for dual 10's.)
it comes with weights for adjusting the tuning. You'll go from ''loud'' to ''very loud'' and ''low'' to ''very low'' ;-)
''If you have a contrarian point of view you are sure is right, donít expect the world to hear angelic choirs and for there to be a sudden catharsis.''
Old 28th October 2017, 10:28 PM   #9
That is interesting. I do have space for two tens in each box. I will look at the internal bracing. What are the pros and cons of passive? And thank you for your input.
Vince
Old 28th October 2017, 11:18 PM   #10
Charles Darwin is offline Charles Darwin  United Kingdom
Volt make a 10" subwoofer, the 2549.
It is happiest in a 42.5L ported cab so 2 would like 85L.
Cost C$285 from Solen.
Personally I am not a fan of drone cones (passive radiators) and would always choose a vented cab over PRs.
Best replacement 10&quot; drivers 0 each budget..Hide this!Advertise here!
Building a "budget" CNC PCB mill. Advice needed. Mayday Equipment & Tools 1 17th June 2016 07:46 PM
Beer budget "Version" of $10,000+ Jamo Open Baffles sreten Multi-Way 216 13th March 2014 11:21 PM
Which budget 6-8" drivers for on-wall cabs? Xiro Full Range 4 12th November 2013 11:00 AM
One 12" or two 8" drivers on a budget? Boscoe Subwoofers 4 16th October 2010 06:25 PM
Need help selecting between two budget 10" drivers percy Multi-Way 3 16th March 2005 10:28 PM
