Best replacement 10" drivers 0 each budget..
Old 7th December 2017, 02:54 PM   #21
compaddict is offline compaddict
I think I am down for eight of these:
Creative Sound Solutions | High End Speakers and Speaker Kits
Any naysayers?
TIA,
Vince
Old 7th December 2017, 06:31 PM   #22
Shaun is offline Shaun  South Africa
Shaun's Avatar
Nay
Originally Posted by compaddict View Post
Any naysayers?
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 7th December 2017, 07:40 PM   #23
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
You only need 2 woofers per channel.
Old 7th December 2017, 08:04 PM   #24
Shaun's Avatar
I see that your T/S parameter data sets are incomplete, missing efficiency and surface area data (and others). I was going to suggest that you also compare SPL, not just gain. There should be a significant difference apparent between the two systems (26l vs 85l).
Do try simming in Unibox, as recommended earlier.
Shaun Onverwacht
Old 7th December 2017, 08:06 PM   #25
Each channel has two boxes with two drivers each.
Old 7th December 2017, 08:42 PM   #26
Brian Steele is offline Brian Steele  Grenada
I wonder how those CSS subwoofers compare against the Type R 10s?
See Alpine Type-R SWR-10D4 3000W Peak 10" Type-R Series Dual 4-Ohm High Performance Subwoofer
Xmax for the Type R 10s is significantly greater.
www.diysubwoofers.org
Old 7th December 2017, 09:12 PM   #27
18.4 VS 20 is that a big difference?
Sorry about not doing SIM home work...
Old 7th December 2017, 09:17 PM   #28
Ah, I misread the information page about the CSS driver. I thought it said Xmax was 12.7mm. It's actually saying that BL is flat for an Xmax of 12.7mm
The Type-R drivers feature pretty flat BL curves as well, but the CSS driver seems significantly more efficient, and likely worth the few extra $$
Old 8th December 2017, 07:54 PM   #29
I just ordered eight CSS drivers on a pre-order special. Sorry for not taking the advice on doing the SIM work.. It's half a lazy thing and half protecting my brain from getting compulsive about something else.
Thanks everyone for all the advice!
Vince
Old 8th December 2017, 08:28 PM   #30
merlinx76 is offline merlinx76  Canada
Vince
They are fairly efficient needing rather large boxes for 10" woofers. They also play just about as low as anything in a ported box modeling lower than most 12" drivers IMO. Now that I sealed the ports and using a shelving EQ to compensate for the lost low end vs ported, I am enjoying them even more. I am running them with about 150W each in 2.2 cu ft sealed right now. Running 4 of them and find they sound pretty good even XO'd as far up as 200hz with a 24dB/oct crossover. I run them up to 150hz now.
Best replacement 10" drivers 0 each budget..Hide this!Advertise here!
Building a "budget" CNC PCB mill. Advice needed. Mayday Equipment & Tools 1 17th June 2016 07:46 PM
Beer budget "Version" of $10,000+ Jamo Open Baffles sreten Multi-Way 216 13th March 2014 11:21 PM
Which budget 6-8" drivers for on-wall cabs? Xiro Full Range 4 12th November 2013 11:00 AM
One 12" or two 8" drivers on a budget? Boscoe Subwoofers 4 16th October 2010 06:25 PM
Need help selecting between two budget 10" drivers percy Multi-Way 3 16th March 2005 10:28 PM
