"Enhanced" Anarchy tapped horn project.
Old 14th October 2017, 12:30 AM   #31
Brian Steele is offline Brian Steele  Grenada
Originally Posted by PB2 View Post
What the tapped horn allows is a much larger "box" but if you build a vented system as a much larger box you get similar results. The TH uses much of the box volume for the long line so they usually end up even larger than the vented design. I believe that we came to the conclusion that the TH might be a few dB more efficient but I doubt it.
FWIW, I took the HornResp sim for my POC3 TH (which was designed for a combination of increased efficiency and extension) and converted the sim to an offset TL of the same volume (basically by changing the sim from TH to OD, then increasing L12 until the passband was flattened.
The results were interesting. See notes below
TH:
Fb=38.36 Hz, max SPL@Fb=111.3dB
Eg for max linear displacement=22V
Passband SPL: 116.4dB@105.9Hz, 115.7dB@72.0Hz,116.0dB@51.1Hz.
Useful up to 135 Hz
GD peaks @43Hz, 16.9mS, minimum@83Hz, 5.2mS, delta=7.9mS
Offset TL:
Fb=38.91 Hz, SPL=112.4dB
Eg for max linear displacement=23V
Passband SPL: 114dB@51.1Hz, 114.2dB@72.0Hz, 115.5dB@105.9Hz
GD peaks @37.2Hz, 19.5mS, 15.14mS@43Hz, minimum @86.7Hz, 2.8mS, delta=2.1mS
From this the TH can produce about 2dB more SPL across the passband (at the cost of a slightly faster rolloff) with slightly less power required to drive it, and the GD performance is better, even more so once the delta is taken into consideration. The additional SPL with good extension was one of the advantages I was aiming for. But here it's just 2dB, and the TH alignment does restrict the bandwidth more than a TL alignment of the same net volume. The GD seems quite a bit better though.
Pictured is the simmed response curve of the offset-TL.
www.diysubwoofers.org
"Enhanced" Anarchy tapped horn project.Hide this!Advertise here!
FS: Erich's Exodus Anarchy tapped horn kits, plus basement sale in Madison, WI tubesguy Swap Meet 12 7th June 2015 02:08 AM
Enhanced L91 Acoustic Lens for JBL / Selenium / PRV WG14-25 (1"), WG14-50 (2") Horn. TomHinton Swap Meet 1 5th January 2015 07:24 PM
Tapped horn sub that fits 30"X30" need help mustang guy Subwoofers 4 24th September 2014 01:09 AM
One 15" Tapped Horn vs Four 8" Tapped Horns Patrick Bateman Subwoofers 28 12th February 2013 10:12 AM
Single 8" or 10" Tapped Horn that can play 20-80Hz maxjr Subwoofers 12 16th January 2011 07:25 PM
Copyright ©1999-2017 diyAudio
