The folds do not match up with the volume you have set as primary restriction. It will be more matching/fixing/work, you seem to like the Anarchy horns, why not just build them?
I will go another route, like the one in my previous post (#39).
Pure aesthetics - I have already built the Anarchy horns, but want something to put under the TP1s instead of behind them. Is it possible to derive FR for a W-Bin Layout using hornresp? This would I assume be a better fit for the smaller volume available, as there is the ported rear enclosure.
