subwoofer position
subwoofer position
Old 8th November 2017, 08:47 PM   #31
umut1001 is offline umut1001  Europe
umut1001's Avatar
Hi.Interesting idea.I have just removed the staplers under the sofa and see that there is about 20cm of empty thickness and about 256 liters of volume under the sofa and also there is extra volume of about same volume after the sponge starts(the thickness of sponge is around 20cm too and finished with faux leather on the top)So there is 512 liters of empty volume in total. I think i will also start to vibrate when i build a downfiring sub under sofa.So i need to seal it right?Has anyone tried without sealing? What happens? Is there any good example around with leather shaking?
"Peace at Home, Peace in the World"
http://stores.ebay.com/Paradise-of-H...dio-components www.hiendparadise.net
Old 8th November 2017, 08:55 PM   #32
umut1001's Avatar
Originally Posted by DonVK View Post
@umut, you can also do your tests at moderate levels (70-80db) , no need to stress the house and occupants.
Haha.The sound was full open by mistake.Yes i will.
Old 8th November 2017, 09:13 PM   #33
DonVK is offline DonVK  Canada
DonVK's Avatar
You're probably not scoring any points, taking apart the family couch.
Old 8th November 2017, 09:19 PM   #34
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Google subwoofer under sofa, or something similar....
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 8th November 2017, 09:39 PM   #35
DonVK's Avatar
I always though the idea of the "coffee table" sub to be a good idea.
You get good bass close to the listener because its usually placed beside a couch. It's a good place to put things (flowers, books, coffee, beer, toys, etc). It also fits into the decor if you design it right and fire the woofer downward to hide the workings.
Old 8th November 2017, 09:48 PM   #36
Yes, make it push-push and it won't shake things onto the floor either
Old 8th November 2017, 09:49 PM   #37
DonVK's Avatar
ScottJ, how's the WAW conversion coming along ?
Old 8th November 2017, 09:58 PM   #38
Dunno, Dave (plant 10) is an advocate and chrisb though they will insist on using the term mid-tweeter. FAST is still ubiquitous on google search. Adding WAW to wikipedia would probably help in that regard
Old 8th November 2017, 10:19 PM   #39
DonVK's Avatar
That's true, I think a lot of people use Wiki. Myself included.
subwoofer positionHide this!Advertise here!
Port Position in a (folded) MLTL: Line position and/or baffle position? 3ll3d00d Full Range 4 18th August 2016 08:40 PM
Transfromers position hego Power Supplies 2 27th January 2015 04:50 PM
Mounting position marka101 Subwoofers 16 15th October 2012 02:50 PM
Adjusting zero position Subwoofer Courtec Subwoofers 2 6th July 2010 03:50 PM
25-position switched attenuator using a pair of 5-position switches? ray_moth Tubes / Valves 1 4th May 2008 08:02 AM
