subwoofer position
subwoofer position
Old 7th November 2017, 11:00 AM   #11
chris661 is offline chris661  United Kingdom
chris661's Avatar
Wow, that's a >40dB hole in the response.
This is going to be difficult to fix.
How low do your main speakers go?
Maybe try reversing the wires on the subwoofer so it's reversed polarity.
Chris
Old 7th November 2017, 11:18 AM   #12
bentoronto is offline bentoronto  Canada
subwoofer position
Data! Great. You're now on the high road to better sound. Fair to say that for many recordings, you'd hardly notice the loss, even if folks on this forum would be aghast at the below-50 hole.
My guess is, you explained things quite well in your original post. That should be clear to anyone who re-reads it. Room modes likely. Sitting close to the wall is probably putting you into a big null reflecting that hole in your response.
Now that you have the tools to measure it, you can move speakers, sitting position, and possibly even furnishings to reduce the problem.
A while back, I posted REW freq response for my music room with a sliding-door clothes closet on the wall opposite my speakers and centred. Closet holds my bulky winter motorcycle gear. Big difference with the door open or closed, in favour of being open and absorbent. In my case, my chair is poorly placed near the centre of the room, not a good place.
B.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and just posted data for a folded 17-foot pipe sub)
Old 7th November 2017, 02:05 PM   #13
chris661's Avatar
Ben, there's a 40dB hole from 45-70Hz. There's a lot of content there that will simply be missing.
You might not notice with singer + guitar music, but anything with even a little bit of bass will be severely lacking.
Chris
Old 7th November 2017, 02:31 PM   #14
DonVK is offline DonVK  Canada
DonVK's Avatar
Originally Posted by umut1001 View Post
Hi.Here is the measurement.I am not sure i did it right.Sorry I have very low information about measurement.(no calibration )
Is it very bad?
If you have REW running, try using the RoomSim feature to enter your room size and listening position. The result will be close, but not exact. Then you can move a virtual "you" and "sub" around to see what works to minimize the room null at your listening position.
Old 7th November 2017, 05:05 PM   #15
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Like you did for me Don. very helpful and accurate too I think OP is going to have to do some moving around, could severely cut either side of the null, but it would be a poor compromise
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 7th November 2017, 05:09 PM   #16
DonVK's Avatar
Yes, and it only takes a few minutes and it will get you very close.
I'm about to do the same exercise, only with 2 subs now. I'm nearly finished my SonoSewerSub.
Old 7th November 2017, 05:45 PM   #17
subwoofer position
Very nice of you to want to educate me more on the frequency compass. I wish I could educate you more on (1) hearing perception and (2) the content of recordings. A good place for you to start is the recent thread about how low do you need to go.
No, I wasn't advocating a 70 Hz cut-off (or for umut101, living with a hole that departed from the 5dB plus or minus band of 40-60).
Apropos the suggestion of re-polarizing the woofer. Yes, no kidding, horrible as it sounds to textbook adherents, sometimes really does the trick. I doubt if applicable here, but sometimes hard to guess which polarity will work best in a given room and speaker set-up. My DSP provides for instantaneous switching polarity of any driver; so I've tried it with my rather dispersed sub(s).
Too bad EQ to boost holes doesn't work for many people. But a chance that with DSP you could finagle some improvement somehow. In any case, hard to have a great system without a DSP (OK, just my opinion).
B.
Old 7th November 2017, 07:05 PM   #18
umut1001 is offline umut1001  Europe
umut1001's Avatar
Hi.Thank you for your replies.I closed the door to improve bass response(like in the car)
I have just checked Room simulation tool.I also simulated with 2 subwoofers but it seems it does not help much.
Sorry i can not change the position of my listening place and subwoofer.
Here with one sub response.I adjusted it same as my closed Subwoofer -3db point just same as my sub.
Graph also seems a little similar to my room response.
It seems ultra flat response drivers not necessary right?Maybe bad response drivers are better and corrected by room Room makes everything bad
"Peace at Home, Peace in the World"
http://stores.ebay.com/Paradise-of-H...dio-components www.hiendparadise.net
Old 7th November 2017, 07:19 PM   #19
Ok. I believe you Have a look at this Corner Dipole Woofer (CDW): info? anyone tried one?
Old 7th November 2017, 07:43 PM   #20
DonVK's Avatar
Swap the left speaker and sub, then move right speaker out to match.
When you measured, was the mic omnidirectional and pointing up (to ceiling) or forward to sub.?
subwoofer positionHide this!Advertise here!
Port Position in a (folded) MLTL: Line position and/or baffle position? 3ll3d00d Full Range 4 18th August 2016 08:40 PM
Transfromers position hego Power Supplies 2 27th January 2015 04:50 PM
Mounting position marka101 Subwoofers 16 15th October 2012 02:50 PM
Adjusting zero position Subwoofer Courtec Subwoofers 2 6th July 2010 03:50 PM
25-position switched attenuator using a pair of 5-position switches? ray_moth Tubes / Valves 1 4th May 2008 08:02 AM
