Plywood thickness for 15 inch subwoofer
Old 5th February 2018, 08:03 AM   #51
S4m is offline S4m  Germany
S4m's Avatar
Heyho,
I collected some experience with subwoofer builds with/without bracings.
The last woofer enclosure i built needed to be very stiff because a 18 inch woofer
from a carhifi enthusiast needed to be transformed into a downfiring hometheater sub.
At first, we made a simple enclosure without bracing and it was horrible sounding.
The walls seemed to work like membranes (22mm plywood).
Then we made some triangles and put two of them per side without huge success.
After I made a bracing as Dave said with connecting the driver by felt to the bracing
the situation was absolutely good and the whole sound went from rattling/muffling
to nice more or less clean bass.
I would guess(without any measurements!) that in planning any kind of box implementing a bracing brings you to a result that you are expecting.
In the end it's only a little bit more sawdust
Old 5th February 2018, 10:03 AM   #52
Brian Steele is offline Brian Steele  Grenada
Originally Posted by globalplayer View Post
Not in my experience.
There is a difference.
You will hear it.
Yup. In my experience, adding braces makes a subwoofer sound significantly better (tested with my POC #2 design).
www.diysubwoofers.org
Old 5th February 2018, 10:29 AM   #53
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Internal bracing will cause "turbulences" and will make the sound somewhat "ugly" in my experience.
Wouldn't turbulences be an advantage?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 5th February 2018, 08:27 PM   #54
Think is offline Think  Netherlands
LOL, that's not what he meant, but you are right.
It's all about the stiffness of the box or minimizing warp in the flat panels of the box.
You can build a canoe with bracing that weighs 20/30lbs or without; then you have model hollowed out tree trunk weighing over 200 lbs; both work.
* It's better to have a system which sounds good and measures bad, then one which measures good and sounds average.*
Old 6th February 2018, 04:05 AM   #55
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
LOL!
That`s not what I meant.
Of course bracing will help when using "thin" walls.
But in my 6th orders internal bracing would make them sound "ugly" as opposed to the clean sound without bracing.
Enough wall thickness will preserve the clean sound while adding sufficient strength.
Old 6th February 2018, 12:47 PM   #56
LOL!
Have you tested this with 2 boxes with the exact same internal volumes, 1 with and 1 without braces?
I think that there is probably something else going on like the braces taking up space/volume, or a brace near a port obstructing airflow.
Old 6th February 2018, 03:07 PM   #57
It was just one box, close to leave prototype state.
I listened to it without bracing, then added bracing in the hope of more db (it was loud already but if you can get more) which went up significantly in higher bass notes.
Listened to it again.
Removed bracing.
All fine again.
Albeit not as rigid.
I think it was a combination of the above^^ since 6th order bps are very unforgiving regarding chamber volumes, etc. both chambers influence each other, ...
It had somewhat more "punch" but sounded somewhat "ugly" with bracing and low end suffered/clarity.
So I removed it.
Being still a MDF prototype which worked surprisingly well it gets occasional use in-car where it is very efficient even with only 100 watts.
Since then I moved on to other BP6 designs which are more rigid due to shape/construction.
Still no internal bracing as of yet.
Old 6th February 2018, 03:14 PM   #58
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
If there is bracing then I would expect to get more reflections of the sound off the rear panels reflected back to the speaker and affect the sound.
Ideally there should be no reflections off the back panels that's why internal padding/sound deadening is often used.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 6th February 2018, 11:20 PM   #59
Adding stuffing or lining to a bandpass subwoofer can reduce the out of band noise. However, it can also reduce the efficiency of the subwoofer. There are better ways of reducing the out of band noise. I've discovered for example that careful positioning of the vent's opening in the vented chamber can null out the first (and most annoying/audible) out of band resonance.
Plywood thickness for 15 inch subwooferHide this!Advertise here!
10 inch subwoofer help Dan21uk Subwoofers 0 25th March 2013 06:58 PM
34 inch subwoofer on youtube nigelwright7557 Subwoofers 12 26th April 2011 06:13 PM
18mm vs 3/4 inch plywood s_aloisio Full Range 11 3rd October 2008 10:14 PM
6.5 inch Subwoofer lawbadman Subwoofers 29 13th July 2005 04:46 PM
Is normal 3/4 of an inch plywood is suitable for a subwoofer? simon5 Subwoofers 37 29th December 2004 09:19 AM
