Simple bass unit using the Dayton PA310
Old 3rd January 2018, 06:38 AM   #41
freddi is offline freddi  United States
freddi's Avatar
regarding the audibility of bass distortion - is that with sine wave? - music? - if the latter, subjectively how does the distortion subjectively manifest itself? darker timbres? - wooly bass ? thud-i-ness?
would you still suggest tuning POC3 TH a bit higher?
Old 3rd January 2018, 02:58 PM   #42
Brian Steele is offline Brian Steele  Grenada
The audible distortion manifested itself at frequencies below Fb (~50Hz), and it was during a swept sine wave test at different SPL levels, which can be particularly hard on vented designs (or any design where the driver is unloaded below a certain frequency). I configured REW to start the sweeps off at 44 Hz and then changed it to 48 Hz for the sweeps at higher power. I still wasn't able to achieve 10% THD in the passband, but I got very close.
I was able to find some temporary stuffing material yesterday afternoon, so I'm going to perform another set of tests today on it, including the filtering suggestion I gave in a previous message.
Hey, I can even make a good recording of it (using the UMM mike) playing back a few tracks. Any suggestions?
www.diysubwoofers.org
Old 3rd January 2018, 03:00 PM   #43
Yes, if planning to use just one. ~40 Hz tuning on a 12" driver with 5mm Xmax for pro audio use is really pushing it.
Old 3rd January 2018, 06:26 PM   #44
The results of the filtering look pretty good - see attached. Basically I minimized the 20 Hz and 31 Hz setting, then increased the 50 Hz setting a bit to compensate and add a little extra at that frequency.
I also tried running it again at the maximum volume I was prepared to drive it. My multimeter suggests that 32.2V at 70 Hz and 37.7V at 50 Hz. It survived the playing of some test tracks with lots of low frequency bass (e.g. "Mi Gente") intact without sounding stressed. At peak levels it did lose that "effortless" sound of the POC3 TH alignment though, but that may be due to my "confirmation bias" at work again
Old 3rd January 2018, 07:18 PM   #45
LORDSANSUI is offline LORDSANSUI  Brazil
good work as always
Old 5th January 2018, 06:56 PM   #46
Fidstang is offline Fidstang  United States
That'll be a good little outdoor bass bin with the processing you did. I think the thickness of the cone on these, also help with the perception of it going deeper than it really is. Be sure to let us know how you feel about it after a few good party sessions.
Old 5th January 2018, 11:20 PM   #47
Interesting you'd mention that. Per the measurement below, the distortion is primarily 2nd order in nature (though at high levels the driver's terminals can be heard buzzing via the vent). We are not sensitive to distortion at bass frequencies, and we are certainly not sensitive to even order distortion at bass frequencies - it can actually make the bass sound "fuller". This might work in this design's favour.
Old 26th January 2018, 02:09 AM   #48
Just a minor update - I've finished the first paint job on the POC6 (which of course exposed all the flaws that need to be corrected). I built this as a sort of "reference", but it might actually end up getting some use outside, so I've got to find a way of protecting the MDF from the elements (the occasional beer spill, etc.). Paint and a good mesh grille for the driver should do the job.
The POC6 actually sounds pretty good, with a nice punchy sound with most music. It's about the third time (that I know about) that the MLTL workbook has been used to successfully design a subwoofer (though with a 48 Hz Fb, and a rolloff that starts a bit above 50 Hz, this is more truthfully a bass module than a subwoofer!).
Old 26th January 2018, 02:27 AM   #49
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Should work well with late 70s, early 80s disco funk or techno.
I like the blue.
Old 26th January 2018, 07:51 AM   #50
USRFobiwan is offline USRFobiwan
Horn Addict
USRFobiwan's Avatar
Can also be a part of a DJ monitor setup. What is the bandwidth? Did you do any measurements?
Destroyed some nostalgia
For the love of Horns and glory of pressure waves.
Simple bass unit using the Dayton PA310Hide this!Advertise here!
small bass unit johnr66 Subwoofers 10 3rd February 2014 10:04 PM
Finally taking the plunge (Dayton PA310-8 TH) Brian Steele Subwoofers 43 4th December 2012 12:17 AM
dayton wright st300a matching / bias trnsformer unit krmaudio Planars & Exotics 14 21st October 2010 12:05 AM
Help for bass unit incloser pra3718 Subwoofers 4 23rd January 2009 02:45 PM
Cracked bass unit nfcgfm Multi-Way 3 17th April 2008 03:29 PM
