Simple bass unit using the Dayton PA310
Old 22nd December 2017, 03:22 PM   #21
Fidstang is offline Fidstang  United States
Brian, just wondering where you were with this. Did you finalize a design?
Old 22nd December 2017, 03:42 PM   #22
Brian Steele is online now Brian Steele  Grenada
I should be starting the build early in the new year. I was going to start it this week, but got distracted by other projects. Basically I'm going to build the first sim that I started this thread with.
www.diysubwoofers.org
Old 22nd December 2017, 03:56 PM   #23
Well, I can't wait to see pictures of the saw dust.
Are you going to flare the port exit or keep it straight, as designed?
Old 22nd December 2017, 04:03 PM   #24
Keeping it straight. Particle velocity at peak output is going to be so low that flaring it is likely to make no difference.
Old 31st December 2017, 11:13 PM   #25
Some build pics. I opted for a 50 Hz MLTL variant.
I was hoping to have it finished by tomorrow afternoon (in time for a beach party), but the weather said otherwise . Probably not a good idea to bring an MDF enclosure out to the beach when there's a chance of rain anyway.
Old 31st December 2017, 11:15 PM   #26
A few more...
Old 31st December 2017, 11:18 PM   #27
freddi is offline freddi  United States
freddi's Avatar
Sweet ! - it should kick better than a small port BR - it could make a nice Econowave type too
Old 1st January 2018, 01:21 AM   #28
Probably not good for a full-range design. While the driver offset should kill must of the 200 Hz organ-pipe resonance, there's the other one at 300 Hz to deal with. It might be lower than sim'd (the folds may help to tame it), but let's see what the measurements say....
Old 1st January 2018, 01:45 AM   #29
freddi's Avatar
its interesting that pa310, with its 3" coil can reach to 5KHz on axis. In this ancient diy copy of a 1955 K12 (no damping material inside), it sounds like it needs a midrange driver to fill to a K-tube tweeter. A 3-way Boom Unit might be cool.
Old 1st January 2018, 02:31 AM   #30
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Hm.
Shouldn`t this ideally be flat or at least kind of flat?
Simple bass unit using the Dayton PA310Hide this!Advertise here!
small bass unit johnr66 Subwoofers 10 3rd February 2014 10:04 PM
Finally taking the plunge (Dayton PA310-8 TH) Brian Steele Subwoofers 43 4th December 2012 12:17 AM
dayton wright st300a matching / bias trnsformer unit krmaudio Planars & Exotics 14 21st October 2010 12:05 AM
Help for bass unit incloser pra3718 Subwoofers 4 23rd January 2009 02:45 PM
Cracked bass unit nfcgfm Multi-Way 3 17th April 2008 03:29 PM
