the "swissroll" compact 8" subwoofer
Old 7th September 2017, 06:12 PM   #141
Pano is online now Pano  United States
Pano's Avatar
Yes, that should work fine.
Did you figure out the EQ trick after looking at the musical spectrum?
Take the Speaker Voltage Test!
Old 7th September 2017, 08:29 PM   #142
robinlawrie is offline robinlawrie  United Kingdom
ha, ive not really looked at it yet.. ive been lost in a world of different amp types and chip selections.. trying to find the best choices within my budget.. there are so many choices and opinions.
ive also just found the 50% discount code for the new TI class d boards..
TI Class D EVM Board 50% Promotion
which has thrown a massive spanner in the works, as they are supposed to be excellent.
im now thinking of buying two of the 3255 boards. they will do 315w into 4 ohms (admittedly with 10%thd) but i doubt i would ever go that loud.
i also assume on a 16 ohm load (the alpairs in series) they will provide a generous but reasonable power level there too.
advantage is the two amps will be identical, meaning same voltage requirements - one big psu for both - cost and space in case saved.
also, as mentioned they are supposed to be great.
wrt the EQ trick.. im not sure i follow completely.. unless you are referring to looking at the graphs for the types of music i like and estimating the area under the graph on either side of the crossover point to see what proportion of the power is required for each "half" ..?
Old 7th September 2017, 09:14 PM   #143
Pano's Avatar
Yes, close to that. You had mentioned wanting to EQ down around 20Hz and were worried about headroom. If you look at my average and peak plots, you'll see what room you have to play with.
The TI deal looks like a good one.
Old 7th September 2017, 09:26 PM   #144
rdf is offline rdf  Canada
rdf's Avatar
Resembles the Genelec 7050B in one of our production suites. They used a rolled aluminum enclosure. The flared, floor-firing port is just visible on the left.
Ears aren't microphones.
the "swissroll" compact 8" subwooferHide this!Advertise here!
How to add "Vu-Meters and "Subwoofer Out" to a tube amp... emretelci Tubes / Valves 7 2nd December 2015 07:23 AM
compact Scoop 12"\15" by Amano (the legend) tda-audio PA Systems 8 10th March 2014 01:07 PM
To sell: one Polk 12" "metallized" subwoofer kencogan Swap Meet 0 16th January 2010 02:21 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
Copyright ©1999-2017 diyAudio
