Compound loading 6th order quarterwave "Super Planar" horns and pipes concepts/builds
Old 11th October 2017, 12:01 AM   #331
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Why don't you like bandpass? FLH = BP4 with a flared port. TH = BP6 with dual flared ports.
Old 11th October 2017, 12:13 AM   #332
Matthew Morgan J is offline Matthew Morgan J  United States
Matthew Morgan J's Avatar
Post Diaphragm pressure
Originally Posted by just a guy View Post
If you want to see those two items, from the acoustical power window go to tools - output. Then switch your output to either one side or the other (not combined). Then those two menu items should be available.
Just A Guy,
Excellent! Now they work .... Thank you for showing me how to gain access ....
How were you living without velocity? Running everything through Akabak?
Hehe, right, i had my roundabout ways if i needed them ..
If you have issues like this just ask, don't just accept that the tool is not available to you. I've been following the Hornresp thread since the first post so I know where most stuff is.
I will, and thank you again Sir
Old 11th October 2017, 12:18 AM   #333
just a guy is offline just a guy  Canada
It's the traditional 4th, 6th, 8th type bandpass I don't care for. I prefer stuff with a little flare flair.
Old 11th October 2017, 12:20 AM   #334
BP1Fanatic's Avatar
Lol!
Old 11th October 2017, 04:57 AM   #335
martinsson is offline martinsson  Sweden
Pressure on the cone is a much more complicated story than just compression ratio. Any cabinet design that increases the efficiency of a cabinet is increasing the coupling between the air and the driver, which is going to generate higher cone pressures.
That is true, the grater the loading the higher the pressure, which is key to efficiency, and no, it's not all about the compression ratio, but it never hurts to consider keeping it as low as possible given driver lifetime and in extreme cases even distortion.
What is of greater importance is how even you spread the forces on the cone, to me it seems pretty straight forward that a symmetrical dual path design will show a more even cone loading then a single path one, all else being equal, and the forces themselves are not dangerous unless you limit the excursion at the cost of proper cooling.
Old 11th October 2017, 05:14 PM   #336
freddi is offline freddi  United States
freddi's Avatar
BP1 - ya gotta luv the sweet & wholesome Karlson too
Old 11th October 2017, 10:49 PM   #337
BP1Fanatic's Avatar
All I know is I prefer the sound of BP4 or BP6 over sealed and BR. I'm tired of the sealed 2-15's in my truck now. I want 6-8's or 8-6.5's in a BP4. I had 4-6.5's in a BP4 in my previous. My son has that box in his apartment at University of Cincinnati.
Old 12th October 2017, 08:50 AM   #338
USRFobiwan is offline USRFobiwan
Horn Addict
USRFobiwan's Avatar
BP1Fanatic being a BandPass Fanatic is an obvious observation
Destroyed some nostalgia
For the love of Horns and glory of pressure waves.
Old 12th October 2017, 04:14 PM   #339
BP1Fanatic's Avatar
Lol!
Old 14th October 2017, 03:09 AM   #340
Lightbulb Folds
A few more fold option concepts that we came up with the other day ........ Rough sketches ....
Compound loading 6th order quarterwave "Super Planar" horns and pipes concepts/buildsHide this!Advertise here!
Can you use 2x 4th order BP boxes to imitate a 6th order BP ? RobWells Subwoofers 26 9th March 2012 08:33 PM
Compound horns, anyone? brsanko Full Range 30 15th August 2011 02:15 AM
6th order bandpass question tinitus Subwoofers 13 8th March 2009 06:01 PM
6th order bandpass Chris8sirhC Subwoofers 1 13th September 2008 07:09 PM
6th-order Bandpass BAM Subwoofers 1 24th September 2001 05:51 PM
