best diy subs - Page 2 - diyAudio
Old 10th June 2017, 05:43 PM   #11
Jerms is offline Jerms  United Kingdom
1 post and that's it?
Assuming this isn't a wind up/prank post.... Spec your sub to meet the level of the rest of your system.
Old 16th June 2017, 01:18 AM   #12
i know RBH are nice speakers.
i would reccomed a minidsp 2x4 and a perhaps 4 12" sealed long throw sus with perhas 250 watts apiece.
the dsp will allow you to integrate the bass between the RBH and 20Hz.
Altec Lansig computer speaker amp, Paradigm atomss, Altec computer sub, Windows PC source
Old 19th June 2017, 11:33 AM   #13
Scott L is offline Scott L  United States
Originally Posted by norman bates View Post
For slamming pounding bass, you need to move a bunch of air 80-200hz.
Chris is right, use many 15's.
Under 80hz is more rumble than slam.
Using same room and subs, double 15's work well for pounding bass, better than many other combinations I've tried.
Very interesting. This is very close to the frequency range where I run my push-pull, slot loaded speakers. ( In my case, 60-250Hz ). But I am only using 2x12's per side. 100db/watt sensitive. The room is a tad bit larger than 3000
cubic feet. I do run subs below 60hz, and I would agree with you, it's mostly just "rumble". Of course this adds to the sense of "scale". Many times in the past, I have recommended the use of 2x15's per side, for a bass solution that does not commit to using "subs". 4x15's per side should be even better !
Old 19th June 2017, 08:09 PM   #14
norman bates's Avatar
I agree, i've had luck with double 15's only (no subs)crossed at 750hz.
There comes a limit for most of how how many boxes we can squeeze in.
DIY Subs electrovert Subwoofers 2 11th June 2014 07:12 PM
Considering new DIY subs dotvibe Subwoofers 7 8th March 2009 06:05 PM
All you with DIY subs Howard Subwoofers 7 4th January 2004 06:38 PM
Copyright 1999-2017 diyAudio
