New Beyma 18LEX1600nd driver
Old 11th April 2017, 06:19 AM   #1
MrKlinky is offline MrKlinky  United Kingdom
Default New Beyma 18LEX1600nd driver
Hi All,
This looks nice, both in appearance and specification:
PL&S
2017 – Beyma | LightSoundJournal.com
THIS SPEAKER IS A TRIBUTE TO THE CITY OF BARCELONA | Beyma Newsletters
LOW & MID FREQUENCY 18LEX1600Nd | Beyma
The BIG question - how much will it cost? I'm thinking it will be approaching £450.00GBP...
Cheers, Carl.
Old 11th April 2017, 08:17 AM   #2
chris661 is offline chris661  United Kingdom
chris661's Avatar
Neat.
Looks like Beyma's response to drivers like the B&C 18SW115. Likely priced similar, or maybe a little under to play catch up?
Chris
Old 11th April 2017, 09:33 AM   #3
Circlomanen is offline Circlomanen  Sweden
B&C Speakers
B&C has released the 18DS115.
A low Qts of 0.20 and a healthy Bl of 39.
Not far from a 8 ohm version of the mighty 18IPAL.
Perfect for front loaded horns, ROAR18 and similar designs.
The Beyma 18LEX1600Nd lacks Bl for any other use then open baffle or bass reflex. Are they Bl-phobic at Beyma?
We live in a horizontal world, why use vertical topologies???
Old 11th April 2017, 05:26 PM   #4
Josh Ricci is offline Josh Ricci  United States
Originally Posted by Circlomanen View Post
B&C Speakers
I really like the direction of the new B&C woofers. The efficiency on these is exceptional and is coupled with a legitimate 15mm of excursion. The 8ohm has a normalized motor strength of 305 and the 4ohm is even higher at 350.
The Beyma linked is a completely different type of woofer. More old school. A little less geometric xmax and a normalized motor strength of only 97? I don't understand the use of NdFeb in the motor if it isn't utilized to generate a stronger field in the gap?
Old 12th April 2017, 11:37 AM   #5
Zero D is offline Zero D  United Kingdom
Lightbulb Beyma 18LEX1600ND v B&C 18DS115
Reflex box = 150L - fb = 42Hz - 24dB LR HPF @ 25HZ - Xmax not exceeded
Swings & roundabouts, as usual Both seem good though ! Price will probably win
Rice Kellog still going strong Not sent from a SpyPhone with CrapApps etc
Old 12th April 2017, 02:26 PM   #6
Rademakers is offline Rademakers  Netherlands
Wait till you have to lift the driver
18" drivers with neodymium magnets are often about half the weight of their ferrite counterparts, meaning about 10 kg/ 22 lbs. less to worry about.
Impossibilities we do immediatly, miracles take slightly longer.
Old 12th April 2017, 02:28 PM   #7
KSTR is offline KSTR  Germany
KSTR's Avatar
Beyma designers sure had a bunch of very good reasons to spec this driver just the way they did.
Old 12th April 2017, 11:41 PM   #8
ErnieM is offline ErnieM  United States
Where does the efficiency show up for the 18DS115? I would've expected it to be more sensitive above 100hz than an 18SW118.
Old 13th April 2017, 07:19 AM   #9
It doesn't !
So would a lot of people, i expect, & not just with this driver. BL is NOT everything, as many might think, or have been lead to believe !
Quoted sensitivities
Beyma 18LEX1600ND - 97 dB - B&C 18DS115 - 98.0 dB - See published graphs though !
Old 13th April 2017, 09:06 AM   #10
USRFobiwan is offline USRFobiwan
Horn Addict
USRFobiwan's Avatar
THe B&C goes down rapidly below 100HZ
Destroyed some nostalgia
For the love of Horns and glory of pressure waves.
New Beyma 18LEX1600nd driverHide this!Advertise here!
Project with Beyma 12xa30nd coaxial driver Audiomig Multi-Way 51 2nd May 2015 02:56 PM
Beyma driver for Wicked One 32 Sub Dust Subwoofers 2 3rd September 2009 08:36 AM
Beyma 1" compression driver cp380M Frankx Swap Meet 2 12th March 2009 06:33 PM
Beyma or Radian 2" driver? oliAudio Multi-Way 0 5th August 2008 08:30 PM
Hands-on experience driver- Beyma SM110/N ttan98 Multi-Way 11 16th May 2008 10:27 AM
