Old 17th March 2004, 11:36 PM   #11
Timn8ter's Avatar
It doesn't surprise me that much. For marketing reasons many designers try to come up with a smaller box. If you trust the parameters you're using then you're numbers are probably correct. But, when dealing with SAF, DIY designers have to come up with smaller boxes too.
Old 18th March 2004, 10:34 AM   #12
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
u can use aperiodic loading to reduce box size to some degree.
...still looking for the holy grail.
Old 18th March 2004, 05:09 PM   #13
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Well.... You could use a ton of Mu-Metal to protect the tv from magnetism, but that would probably be expensive and unstable since the vibration from the subwoofer might cause it to lose its magnetic shielding properties, which are obataind through the process of annealing.
As for vibration, yes, this will cause microphonic vibrations in the tube and distort the picture visually if the vibrations are great enough. I've done this without the sub or speakers even near the tv and in that case it's unavoidable without removing the tv. Though, the vibrations occurred for over a year of listening and never caused a problem with the tv.
And aperiodic loading, I might add is something I've grown to like.
It can really make a small box seem big to the right driver. I have a driver with a VAS of over 300L and the aperiodic measures of the cabinet let me have a smaller one.
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Furniture doubling up as Subwoofer? anm Subwoofers 33 5th July 2011 05:09 AM
A DIY piece of furniture for your DIY HIFI stuff? Bricolo Everything Else 74 31st August 2003 10:14 AM
subwoofer as furniture flux01 Subwoofers 4 5th August 2003 05:55 PM
subwoofer furniture flux01 Subwoofers 4 2nd August 2003 01:07 PM
Page generated in 0.06171 seconds (71.21% PHP - 28.79% MySQL) with 10 queries
