I'd like some input on this design please, specifically the stacked nature of the step sections, and the centre mounting.
The driver is Kenwood KFC-W112S (200W, 25Hz-800Hz), Chamber=19.2Litres, Throat=62mm*62mm and Mouth=1006mm*1006mm.
With a *2 area increase every 15", there's approximately 1.5-2metres of horn length.
Main Box dimensions - 1006mm(H)*1006mm(W)*671mm(D).
Driver Chamber dimensions - 310mm(H)*310mm(W)*201mm(D)
This is not an acoustic exercise, the cabinet will be bolted into the back of my van with a couple of 6*9's stapled to the top, but it would be nice to get it as close as possible to the driver's bottom end.
SM
SM
