Vintage JBL for subwofer
Old 18th March 2017, 09:03 PM   #21
academia50 is offline academia50  Argentina
Originally Posted by bentoronto View Post
Be skeptical (esp for LPs) until you've actually seen those low notes on a real-time analyzer such as included in REW (free or honourware).
B.
Is that I do not need the spectrum analyzer, I hear these deep notes perfectly (not 16 hz, of course)
Old 18th March 2017, 10:08 PM   #22
bentoronto is offline bentoronto  Canada
It is beyond my poor powers of explanation to reply your reply in any productive manner. Except to suggest you try a real-time analyzer, just in the odd chance you hear not as "perfectly" as you think you do. Just a thought, eh.
Ben
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and just posted data for a folded 17-foot pipe sub)
Old 19th March 2017, 06:02 AM   #23
jazbo8 is offline jazbo8
jazbo8's Avatar
But they are products for PA, and something expensive for the investment I want to make at the moment ...
You don't need that much power for home use, try the smallest one they make, I think it's called the NU1000DSP. I doubt you can build one for less money nor have the DSP feature.
Old 19th March 2017, 08:10 PM   #24
Thank you , this model offers everything I need and more ......
Just a doubt, and I ask again all those who can explain this to me:
The higher the load in class AB, the lower power.
Is it the same in class D?
Or put another way, can I connect my vintage JBL 8 ohms nominally without problems? Can I even increase the load with high heat dissipation resistors to reduce the risk of damaging the speakers? (This increases the distortion, but at these frequencies I do not think they are audible)
I am going to consult the seller (they are not usually very technically informed) so I would like to clarify the point with people of this forum, thanks again !
Behringer Inuke Nu1000dsp Potencia 1000w - $ 9.310,00 en Mercado Libre
Old 19th March 2017, 08:37 PM   #25
Amps operate according to their internal voltage level (and sort of secondarily for present purposes, on the current in storage internally).
So if they have say, 30 volts (sort of RMS....), that's all they can pump out (assuming for present purposes that they don't run out of current).
If you connect a 4-Ohm load, they can produce, so to speak, 30 volts into 4 Ohms which is 225 watts, let's say.
if you connect an 8-Ohm load, that's 30 volts into 8 Ohms or 112 watts*.
Not the whole story but enough of the story for the amp for a generic answer.
But what the driver produces as sound output is a partly different story.
Ben
*a speaker with 1% efficiency would soon destroy your hearing at 112 watts input
Old 19th March 2017, 09:09 PM   #26
Fenalaar is offline Fenalaar  Norway
You don't want to add a resistor in the cirquit of a sub. A subwoofer in its frequency band will have an impedance that can vary from 4 ohms to 120 ohms, so a resistor will create a highly unlinear voltage divider.
You generally want the sub to be connected directly to the amp for maximum damping factor and control.
The iNuke has level controls, so turn down the senitivity so you can reach you max listening level and then some. That'll keep the damage potential down.
Johan-Kr
Old 20th March 2017, 09:11 PM   #27
bentoroto an Fenalaar
Thank you so much, I'll go after him then , there was no free lunch here, no sir .....
Old 21st March 2017, 11:43 PM   #28
Grrrrrrr ........ there seems to be mutiny on board, WAF does not agree to keep spending money on these things and claims that I pay attention to their needs ......
Of course, how can I explain to her that I want to hear the first two octaves that I am missing after two years of building the best speaker in the world ?
It does not matter, as she lets me do it, but without investing more money in my "obsessive maniac", I return to the previous idea of using the junk that I have thought about this.
(See post 19 of this thread)
Comments ? Some major disadvantage (danger) that could blow everything up?
I Sorry, Plustek Optic Pro has not yet updated its drivers for Win 7, the last one was for Win 95 ...... I had gotten one in the informal lane for WinXP, but it does not work either plus ....
File Type: jpg Pasa bajos para el sistema stereo y HT.JPG (392.4 KB, 116 views)
Old 22nd March 2017, 01:43 AM   #29
Forget this, the subwoofer cutting frequency is 90 hertz ....
Old 22nd March 2017, 03:40 PM   #30
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Default JBL-LE14A
Hi All,
FYI:
b
Vintage JBL for subwoferHide this!Advertise here!
Reviving vintage JBL cabinets MichaelM86 Multi-Way 32 29th September 2014 02:02 PM
Vintage Richard Long Bertha/vintage JBL artscrafts14 PA Systems 6 5th July 2012 07:19 AM
FS: Vintage drivers- SEAS, JBL, Jensen, Bozak, etc GordonW Swap Meet 1 3rd April 2011 04:52 PM
Subwofer Filter Schematic Problem hernanstafe Parts 1 16th March 2007 09:15 AM
Scan Speak 21W8553 based subwofer. aeon Subwoofers 11 17th November 2004 05:50 PM
