High-end Sub/woofers comparison: Faital V.S. JL audio - diyAudio
Old 9th January 2017, 05:24 AM   #1
Exclamation High-end Sub/woofers comparison: Faital V.S. JL audio
Was curious about the PA drivers v.s. ''real'' high excursion subwoofers such as JL audio's, and finally tested this week end a single Faital pro 18FH500 in a 65 liters sealed enclosure against a pair of 10W7 in sealed 30 liters each. Bother ICEpowered with a 1000ASP and aggressively EQ'd in the 24-32hz, as i usually do.
Maybe i was a bit too optimistic about the 18FH500 (that was looking very promising on paper) but the pair of JL's really smashed the 18'' in the ropes. We're talking about a 88-92db in-room measurement for the Faital, before the mechanical/distortion noise kicks in, and between 99-104db for the pair of 10W7.
All using pure tones between 20hz and 30hz.
Despite his higher Fs, the 10W7 was really at ease in the first half of 1st octave. Effortless, controlled pistonic air-mover. Room pressurization, almost inaudible at 20-22hz (as it should) but that can be felt alright enough above 100db!
Once again, the JL audio impresses me.
Agreed, once pass the first octave, the 18FH500 qualities probably shows. But still, there is no substitute to a ''real'' subwoofer for the first octave, especially the 20-30hz region.
''If you have a contrarian point of view you are sure is right, donít expect the world to hear angelic choirs and for there to be a sudden catharsis.''
Old 9th January 2017, 07:38 AM   #2
USRFobiwan's Avatar
Ok, now play it for about 5 to 8 hours at war volumes.
Old 9th January 2017, 08:22 AM   #3
Kinda not surprised in a way Jon - do the maths on the VD for both options - Two 10W7 has almost double the volume displacement.......
There is no replacement for displacement in sub base.....
Old 9th January 2017, 08:26 AM   #4
Attached : Rear chamber pressure sim comparison between faital in 65 liters VS 2xJL in serie in 65 liters. At 30hz, twice pressure for the faital, arround 107db for both, 50v.
=> In 65 liters, it just doesn't breathe healthily, and pressure mecanical problem.
I had never used hornresp for/like that before, but should be promising. Can someone confirm my explanation ? (it seems me counter intuitive, related to volume displaced should be equal for same acoustical power...?)
Old 9th January 2017, 11:46 AM   #5
To complete, Faital got a mms=114gr, for a 18" cone + is voicecoil. It's really light, and not for closed box imo.
Old 10th January 2017, 12:05 AM   #6
You think the JL audio will suffer from heat compression ?
I think not.
Especially not the W7 series, which was made for the worst of wars: in the trunk of a basshead's car.
If pushed both to 90% of their Xmax, i'd say the Faital would fail first.
Old 10th January 2017, 12:09 AM   #7
1776cc for the pair of 10w7
and 1049cc for the 18FH500, yup you're right.
I forgot how crazy the xmax was on the 10W7...
Old 10th January 2017, 12:11 AM   #8
...and, not bad, 1847cc from a pair of 12W6v3.
Old 10th January 2017, 12:54 AM   #9
18FH500 is NOT a subwoofer neither it is high end. It's a bass speaker. Now try a real subwoofer driver like the 18XL1800 or equivalent if you want a fair match . 100$ on the Faital. 4dB more headroom vs a pair of JLAudio in the same enclosure size at less than half the price.
40% less excursion at the same SPL.
2 x JLAudio 10W7: 1400$
1 x 18XL1800: 664$
1x 18HF500: 344$
2 x 18XL1800 would destroy the JLAudio for less money.
Do your way, it's the only way.
Old 10th January 2017, 02:47 AM   #10
you'll have to order it this time, i had my share of audio stuff buying for the last months :-)
i'm sure the 18XL1800 is an awesome driver. But then i'll bring my 18 RE XXX, and we'll do some 15 hertz pumpin'
High-end project Yuichi a-290 and Faital pro 18FH500 allec Introductions 1 4th September 2016 08:26 PM
high end mids and woofers and HDS Tweeters vactor Swap Meet 9 31st July 2014 01:36 PM
USB socket comparison for high quality and high demand audio usage diyinhk Parts 2 12th June 2014 12:53 PM
hertz audison focal JBL JL alpine high end sq for sale! JohnnyBASS Swap Meet 0 9th January 2012 06:32 PM
High End CD Player Comparison Mohan Varkey Digital Source 0 6th March 2004 09:45 PM
Copyright ©1999-2017 diyAudio
