High-end Sub/woofers comparison: Faital V.S. JL audio - Page 2 - diyAudio
Old 10th January 2017, 02:48 AM   #11
...can't believe i still have this 18 RE XXX sitting around... damn, i have too many drivers...
''If you have a contrarian point of view you are sure is right, donít expect the world to hear angelic choirs and for there to be a sudden catharsis.''
Old 10th January 2017, 02:52 AM   #12
https://youtu.be/CZZ0AvqKuo8?t=79
haha
If i remember correctly:L
Fs 15hz
Xmax 54mm
That's about as crazy as it can get.
Old 10th January 2017, 06:29 AM   #13
Originally Posted by papasteack View Post
Attached : Rear chamber pressure sim comparison between faital in 65 liters VS 2xJL in serie in 65 liters. At 30hz, twice pressure for the faital, arround 107db for both, 50v.
=> In 65 liters, it just doesn't breathe healthily, and pressure mecanical problem.
I had never used hornresp for/like that before, but should be promising. Can someone confirm my explanation ? (it seems me counter intuitive, related to volume displaced should be equal for same acoustical power...?)
Hi papasteack,
What input parameter values are you using?
I get a different result to you for the two JL Audio 10W7-3 drivers connected in series.
Kind regards,
David
www.hornresp.net
Old 10th January 2017, 11:32 AM   #14
Sorry for confusion, just tested again, got same result as you master David ^^
Old 12th January 2017, 04:34 AM   #15
Excellent :-).
www.hornresp.net
High-end project Yuichi a-290 and Faital pro 18FH500 allec Introductions 1 4th September 2016 08:26 PM
high end mids and woofers and HDS Tweeters vactor Swap Meet 9 31st July 2014 01:36 PM
USB socket comparison for high quality and high demand audio usage diyinhk Parts 2 12th June 2014 12:53 PM
hertz audison focal JBL JL alpine high end sq for sale! JohnnyBASS Swap Meet 0 9th January 2012 06:32 PM
High End CD Player Comparison Mohan Varkey Digital Source 0 6th March 2004 09:45 PM
Copyright ©1999-2017 diyAudio
