Tapped Horn for B&C 15NW100 Tapped Horn for B&C 15NW100 - diyAudio
Old 2nd January 2017, 05:41 PM   #1
martina is offline martina
Question Tapped Horn for B&C 15NW100
Hello,
we have 12 B&C 15NW100 here.
What's the best choice for a Tapped Horn Design for this driver from 40Hz to 120Hz?
Best regards
Old 2nd January 2017, 06:46 PM   #2
Rademakers is offline Rademakers  Netherlands
The THAM15.
Johan
Impossibilities we do immediatly, miracles take slightly longer.
Old 2nd January 2017, 07:17 PM   #3
GM is offline GM  United States
GM's Avatar
Greets!
'Best'? Don't know, but here's a very simple ~153 L [net] one using published specs that if all [12] were tightly stacked with only 500 W ea. will in theory put out around 145 dB/m setting on the ground or massive stage:
GM
File Type: txt BC15NW100TH.txt (953 Bytes, 94 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 2nd January 2017, 09:47 PM   #4
sonomanie is offline sonomanie  Belgium
TH 15" flat response to 35Hz (-3dB) - By LORDSANSUI
Old 5th January 2017, 04:09 PM   #5
Originally Posted by GM View Post
Greets!
GM
What i must do with the .txt file*
Old 5th January 2017, 05:41 PM   #6
epa is offline epa  Netherlands
import the file in hornresp
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 6th January 2017, 02:55 PM   #7
USRFobiwan is offline USRFobiwan
USRFobiwan's Avatar
Here is the sim in the default THAM15:
2.83 (1w)
80v (800w) @ xmax
Seems to sim ok, but 40Hz is hard to get with the Tham design.
I also load in the sim from GM, but I do not like the result.
Old 6th January 2017, 10:13 PM   #8
tb46 is offline tb46  United States
Hi USRFobiwan,
Post #7: "...40Hz is hard to get with the Tham design.
When you add the bottom segment as Forsman did you can get there:
Thorn F1 - a learning experiance with Tapped Horn
I drew one up W=23-7/8" D=23-7/8" H=31-7/8", and it looks fine w/ the B&C 15NW100. I can post the drawing if there is interest, it is larger than the original THAM15.
File Type: png THAM15_Forsman_Mod_2_15NW100_Schematic.PNG (13.0 KB, 300 views)
Oliver
Old 6th January 2017, 10:28 PM   #9
Hi tb46,
a drawing was very interesting for me.
Can you post it here?
Best regards
Old 6th January 2017, 11:04 PM   #10
Hi martina,
No problem. It was originally designed for a different driver, but the 15NW100 should work in it too. I can make additional drawings for internal dimensions, etc.
Oliver
Tapped Horn for B&C 15NW100Hide this!Advertise here!
Tapped horn for B&C 15TBX100 th115 style Dref Subwoofers 14 13th August 2014 12:36 AM
FS: 1KW tapped horn sub and 700W amp andyboy Swap Meet 0 17th March 2012 01:16 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Copyright ©1999-2017 diyAudio
