Clearest subwoofer out there?
Old 28th November 2016, 03:39 AM   #1
Denali driver is offline Denali driver
Default Clearest subwoofer out there?
Okay I have a 2015 gmc denali 1500. It comes stock w Bose door speakers but some songs sound flat. The back seats flip up so there is plenty of room for two subs. I don't want heavy bass. I want very clear sounds. I don't mind a little bass but when you can't even hear the words because of the bass that isn't my preference. Does Rockford fosgate make a system that sounds clear?? What's the clearest, purest sounding sub out there? Thanks
Old 29th November 2016, 02:40 AM   #2
reloader650 is online now reloader650  United States
Hi Denali,
Rockford, JL Audio, and Alpine make some great subwoofers. How clean they sound or how well they blend with the rest of the system depends on box type, EQ and gain settings. You need to figure out what your maximum dimensions are under the seats before picking a driver. Before you buy you must take into consideration mounting depth, available box volume, power requirements (space for amp). Please let me know if you have any more questions.
Matt
Old 29th November 2016, 03:14 AM   #3
mordikai is offline mordikai  United States
Send a message via Yahoo to mordikai
The alpine both the s and r series are great for the money. I have had a pair of Dayton ref series ho 12's in my car and they are also excellent for the money. For car I always go for small sealed cabinets with a q of between .8-.9 and f3 of 40-50 hz. Seems to work well in most cars with most music.
Old 29th November 2016, 03:48 PM   #4
zobsky is offline zobsky  India
zobsky's Avatar
If "clean" is what you're after, Dayton HO are what I would recommend. I've used the 12" version for a car and the 15" version for a HT sub.
For the car version (toyota camry trunk install), I settled on about 1.7 cuft net tuned to 27 Hz (I tried an port length corresponding to 22 Hz tuning and it wasn't punchy enough). FWIW, If you can spare a bit more space (box of about 2 cuft or a bit more), you can get even better performance.
I also built a test sealed box of about 0.85 cuft that was very clean and accurate and dug lower than the sealed box but didn't have the impact.
Play with winisd and see what you get.
Hope that helped
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 31st December 2016, 01:37 PM   #5
HumbleDeer is offline HumbleDeer  Belgium
HumbleDeer's Avatar
Hope that helped
The HO's are indeed good choices if you're really after quality. They're easy to work with, as far as I know also very soft in surrounds and spider and the coil gap is pretty small which means less loss of megnetix flux :P
I have an HFA series woofer myself and I'm really happy with it.
Old 1st January 2017, 01:41 AM   #6
JonBocani is offline JonBocani  Canada
JL audio hands down.
W1v3 series would be more than enough for your needs.
Car Audio - Subwoofer Drivers - W1v3
''If you have a contrarian point of view you are sure is right, donít expect the world to hear angelic choirs and for there to be a sudden catharsis.''
Old 9th January 2017, 02:21 PM   #7
Taterworks is offline Taterworks  United States
Taterworks's Avatar
Step 1, try decreasing the Bass tone control on your head unit and increasing the Treble tone control.
If that doesn't stop your issue with excessive midbass then proceed to step 2.
Step 2, locate and disconnect the "Richbass" woofer in your vehicle. It may be in your center console in that model, but sometimes it is a module that fits inside the spare tire. This will decrease the amount of bass you hear, and the remaining bass will come from your door speakers.
If it works, but you don't know why it works, then you haven't done any engineering.
Taterworks Audio (nothing for sale)
Old 10th January 2017, 03:31 PM   #8
stewin is offline stewin  Kenya
if it is for p.a or home theater danley's th118 number 1 in clarity
Old 17th January 2017, 07:54 AM   #9
Greebster is offline Greebster  United States
Greebster's Avatar
Regardless of what driver is used it is more important to know how the sub system will interact with the Denali's acoustic signature. For that you must use a calibrated mic and software like ARTA or REW. Once that is known the vehicles acoustic profile must be included into sub's design. To me what you want is closer to what a true high fidelity system sounds like and my advice must be heeded to accomplish.
I installed a system in a 2009 Jeep off road "Mudder" last year. Owner dropped over $20k in it's upgrades. I did not get the choice of what was being installed and the owner turned into a kid in a candy store and just bought what the local shop sold him on. JL Audio. I triamped the system and used a miniDSP 6x8. Tweaked all that I could but there were some major issues like 6.5" midwoofer underdash mounted and 50 degrees off axis crossed to the matching coaxial tweeters he had installed into the pods on top of the dash. JL thought it fine to cross these at 3.3kHz. Today there is a big hole in the upper midrange because I wasn't the one that choose the drivers. He was happy with the end result and I thought it sucked. Outside of the vehicle it sounded fine enough, inside was another matter altogether. The only thing it did well was get LOUD. He did not have enough patience for a final tweaking (or ten).
The store said they would install it all for $250 with one caveat, they could not do active DSP based systems! This was from the best, most highly regarded shop in town. WOW
Also the miniDSP 6x8 was not his first choice. The other active crossover died after three days. Said he had done his research prior to purchase. I discovered right off the rip that it was a POS and many others had the same issue, even with multiple replacement devices. The miniDSP based solution I said to get, had only been on the market for less than a month at the time, is still working like a peach today.
Old 17th January 2017, 03:13 PM   #10
troystg is offline troystg  United States
troystg's Avatar
If he has a "Richbass" module another common solution is to open it and add polyfil...
Troy
Thinking positive doesn't make things better, it makes you a better person.
Clearest subwoofer out there?Hide this!Advertise here!
FS in Los Angeles: subwoofer, subwoofer cabinet, oscilliscope, KEF center... taloyd Swap Meet 61 13th December 2017 08:14 PM
Overview about words largest Subwoofer Drivers/Transducers (SUBWOOFER BEAST) tiefbassuebertr Subwoofers 27 9th September 2012 10:42 AM
FS: Dayton Reference Subwoofer RSS315HF-4 12" Subwoofer Driver matevana Swap Meet 0 12th February 2012 03:42 PM
Subwoofer build - Morel UW1258, 12" Ultimate Subwoofer mantha3 Subwoofers 46 10th October 2011 02:11 PM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 04:19 PM
Copyright ©1999-2017 diyAudio
