Modifying a Definitive Technology Subwoofer - diyAudio
Old 16th November 2016, 09:59 PM   #1
juliopr is offline juliopr  Puerto Rico
Default Modifying a Definitive Technology Subwoofer
Hello everyone.. I would like to ask for some advice on which would be the best way to repair and also improve a Def Tech Powerfield 15 sub. The original driver got busted by accident and I was considering replacing it with a Dayton Audio RSS390HO-4 unit because of its efficiency (92db), and add 2 CSS APR15 passive radiators to the sides. My first choice was going for the HF version of that sub, but the tech specialist at PE told me to go for the HO version for that box, but no other suggestion or advise so far. The amp is 185 watts RMS A/B. I will definitely appreciate any kind of advice or comments
Old 20th November 2016, 08:04 AM   #2
Dofus is offline Dofus  Sweden
you have checked so it's none of defun techs 75 ohm systems ?
Old 20th November 2016, 02:30 PM   #3
Sensitivity means nothing below 100 Hz (meaning quoted sensitivity). Driver T/S parameters will determine how well it works in your existing box. Do simulations of the box volume and see which driver is more appropriate for the volume that way. The suspension/compliance will dictate which of those two you mentioned will be better. Most important dimension will be cutout size. Unless you plan on routing a bigger whole make sure whatever driver you find has the same through whole size and make sure you are willing and capable of drilling new holes for T-nuts as I doubt those will be on the same radius and the replacement.
Old 21st November 2016, 10:43 PM   #4
Hello... no. the driver was a 4 ohm unit as stated on a sticker attached to the magnet.
Old 21st November 2016, 11:25 PM   #5
Hello and thanks for answering.. the driver its just right.. a little of filing will just do... but I have something else in mind... I plan to build a box around the original so it will have 1-1\2" walls to accomodate the new sub driver on the front with the right hole and the 2 passive unit at the sides. With this I intend to make the box less resonant no matter if it becomes heavier since this unit will stay put. I just mentioned the efficiency since most subs nowadays ate 82, 86db efficient, so I was looking at this detail since the amp that comes with it is only 185 watts rms Class a/b.
Old 25th November 2016, 11:40 AM   #6
Sounds like it would be easier to build a new cab from scratch
Definitive Technology upgrade sc1984 Multi-Way 1 30th January 2016 05:54 AM
Definitive Technology Schematic rjneufeld Subwoofers 3 12th August 2014 10:27 PM
Definitive Technology PF15tl weccjc67 Subwoofers 2 18th February 2013 03:26 AM
definitive technology ampimp Multi-Way 4 1st November 2010 03:27 AM
Definitive Technology drivers help? razageorge Multi-Way 2 7th October 2009 05:12 PM
Copyright 1999-2017 diyAudio
