TH 15" flat response to 35Hz (-3dB) - By LORDSANSUI
Old 8th January 2017, 03:32 PM   #111
lm324 is offline lm324  Brazil
SNAKE PROFISSIONAL - Ultrapark Group
bye
Old 8th January 2017, 11:46 PM   #112
LORDSANSUI is offline LORDSANSUI  Brazil
The company was sold after some problem after his founder death.
TO check the products you can surf at the old one that still have all datasheet but they are in Portuguese.
Produtos
Old 9th January 2017, 01:20 PM   #113
turbodawg is offline turbodawg
Hi, have you done any sims with the B&C 15TBW100? Thanks!
Old 9th January 2017, 09:54 PM   #114
Zero D is offline Zero D  United Kingdom
@ lm324 & LORDSANSUI
Thanx
Rice Kellog still going strong Not sent from a SpyPhone with CrapApps etc
Old 10th January 2017, 02:51 PM   #115
stewin is offline stewin  Kenya
hi lordsansui , is tapped horn louder than bandpass box ,for example the nexo ls series??
Old 20th January 2017, 09:00 PM   #116
@ USRFobiwan
The option A and B were left in the past, due to diaphragm displacement i tunned the project to safety region, you can find it on the history or wait some more posts will i complete the build so i will repost the design again.
@ turbodawg
Yeah, i simulated all drivers from the list posted on the topic #105 and I don't recommend the B&C 15TBW100 for this spec, see below the response @2,83V. To use it you should change a lot the dimensions.
Left the frequency response comparison between Snake HPX2150 and B&C 15TBW100, and right just the B&C one.
Direct image link https://s29.postimg.org/t0zpfx33r/15_TBW100.png
@ stewin
I never build a bandpass cab, from what I read till now, it can be more efficiency then tapped horn but, people always complain about it being a kind of "one note" cab and it maybe this came from high distortion additionaly it has more restricted bandwidth frequency response. So I think for who need just SPL it's a good option, for who need SPL and HI-FI response looks like Tapped are way better.
There are many guys much more experience then me to help you in this case.
Old 5th February 2017, 12:32 PM   #117
I just bought the polywood and the build process begun.
Direct image link: https://s23.postimg.org/dp19lzdyj/P_20170203_190913.jpg
Direct image link: https://s27.postimg.org/la5wcy91v/P_20170203_194148.jpg
Direct image link: https://s24.postimg.org/68zxl1ec5/P_20170203_212317.jpg
I will build 4 of them and I don't have much margin for errors so I decided to increase thickness from 15mm to 18mm, the dimensions were adjusted to keep the same frequency response as 15mm, so for who wanna build with 15mm that plan still works.
For 18mm here are the data updated.
Hornresp input data
Direct image link: https://s28.postimg.org/9c76i8qgd/SS...8mm_Inputs.png
Frequency response
Direct image link: https://s24.postimg.org/kkdsajxed/SS...al_18mm_FR.png
18mm polywood plan
Direct image link: https://s23.postimg.org/83gqatgbv/SS..._18mm_Plan.png
Bracers and cone correction (2,35 L from the driver + 0,87L from bafle circular cut = 3,24 L total cone correction)
Direct image link: https://s23.postimg.org/nr4p6okt7/SS...mm_Bracers.png
Old 5th February 2017, 03:49 PM   #118
tb46 is offline tb46  United States
Hi LORDSANSUI,
Looks good. As always, let's hope the T/S parameters are correct. Will you be able to make measurements?
Oliver
Old 5th February 2017, 10:09 PM   #119
Hi Oliver,
I don't know how to proper mesure the T/S, maybe is not hard, but I'd like to measure frequency response first. Snake is the best Brazilian company for drivers and used to be very reliable, but we never know
Do you have any documents about how to measure both of them?
Old 6th February 2017, 02:08 AM   #120
Brian Steele is offline Brian Steele  Grenada
Unfortunately I jumped (again?) into this thread a bit too late, but here are some suggestions for v2 of your horn, if you ever come to that.
1st of all is to remove the "dead" space in your horn by adjusting the layout to take into consideration a longer path length AND the cone compensation that you want to insert into the design. you can either achieve a lower Fb or, if you want, resize the horn a little smaller to bring Fb back up to your target.
2nd is to use the bracing scheme I've tried to illustrate in the picture. Use solid 1/2 ply, with cutouts for where the internal panels fit in, and perforate the rest with a circle saw. Use two bracing panels like that and that should basically kill any vibration on the top external panel. If you do NOT brace that top panel properly, it may end up tossing whatever you put on it. Ask me how I know this .
Finally, consider inserting damping material into the section of the horn as illustrated - this will reduce the ripple above the passband with minimum impact in the TH's passband.
www.diysubwoofers.org
TH 15" flat response to 35Hz (-3dB) - By LORDSANSUIHide this!Advertise here!
TH-18 Flat to 35hz! (Xoc1's design) m R g S r Subwoofers 2767 9th June 2018 01:35 AM
OTH40C 15" loaded Compact TH Flat to 40hz sine143 Subwoofers 68 30th October 2016 02:46 AM
Flat FR, Flat Power Response, in-phase crossover? RockLeeEV Multi-Way 15 7th February 2012 08:07 PM
DCGold fullrange cones 35hz -3db @96db sensitivity?? human.bin Full Range 20 26th February 2010 01:34 PM
