Pairing 2 sub speakers to one amp - diyAudio
Old 9th October 2016, 04:34 AM   #1
ukrkoz is offline ukrkoz  United States
Default Pairing 2 sub speakers to one amp
Ok, my Energy 12 inch 300W sub pooped. Keeps blowing fuse.
I just installed a Polk 505 12 inch powered sub and it works, but Energy had a much better sound.
Energy driver works. And it's a nice downfiring box.
Can I run energy driver paired with Polk one? If yes, how? What's the proper "splicing"?
Or, simply disconnect Polk driver and run extension to the Energy one? And use that one?
I sorta do not mind using both, ha ha.
Old 15th November 2016, 08:48 PM   #2
NH7RO is offline NH7RO  United States
Default Driver impedances?
Before you go hooking them up together you need to determine each driver's impedance; if they are both 8 ohm---great---you can run them in parallel. If both are 4 ohm you might want to run them in series unless your amp can handle 2 ohms.
If both are different I think you are out of luck; perhaps someone else might be able to help with other ideas.
Old 15th November 2016, 09:52 PM   #3
Got it!
I can do that.
Polk I got is Ok but nowhere as good as that Energy one was. Will get on it after work. Thank you.
Pairing new speakers with existing amp apieroni Chip Amps 2 2nd August 2016 01:20 PM
Realistic 40-1354A enclosures and tripath amp pairing johnnygrace Full Range 17 15th January 2014 09:46 PM
Need help pairing Martin Logan Sequel II speakers with 4 Watt tube monoblocks areniers Tubes / Valves 10 12th May 2013 09:06 PM
Pairing? solly98 Multi-Way 0 28th November 2012 01:15 AM
pairing up speakers correctly. iggy18 Multi-Way 3 10th July 2012 02:26 PM
Copyright ©1999-2017 diyAudio
