BMS 12S330 for a folded horn? - diyAudio
Old 2nd August 2016, 10:17 AM   #1
Augusts is offline Augusts  Latvia
Default BMS 12S330 for a folded horn?
Hello,
I recently bought two BMS 12S330 subwoofers. What do you think about putting them in a folded horn enclosure? They can be used from 25-300 hz but I dont know all the cans and cannots for folded horns. I have tried using the Horn resp but I have never understood how can you get a reasonably sized box and a nice frequency response. I am lost here, my thinking does not work in this sector..
A
Old 3rd August 2016, 06:43 PM   #2
JLH is offline JLH  United States
JLH's Avatar
You can't get a reasonable sized enclosure using a horn. The lower the frequency, the larger the horn. Placing a horn in a corner will help reduce the required mouth size by providing boundary reinforcement. However, it will still be very large. A 25Hz wavelength is approximately 45 feet long. The minimum length for a 25Hz would be about 11.25 feet long and require a mouth size of around 20 sq. ft. when placed in a corner.
John Inlow has built some bass horns that make several intelligent compromises. See his web page at this link: Spiral Bass Horn - The Paper Horn by Inlow Sound
He makes it work by trading some extra excursion for low end bandwidth by boosting with DSP. Its still a huge horn, but more reasonable in size than some other solutions I've seen.
If you are open to using a Tapped Horn instead of a front loaded horn, things can be made smaller. However, it will require more power because it won't be as efficient or have well behaved impedance curve as a front loaded horn.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 5th August 2016, 07:55 AM   #3
epa is offline epa  Netherlands
be more specific
what purpoce, home theatre, music,pa?
freg range ,size limmits.seperate amp, dsp
its a nice driver to do something with.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 6th August 2016, 10:03 AM   #4
Hey, thanks for the answers, very inspiring and informative
Ill be using it for PA, it would have a proper seperate amp and a DSP on the system. The range would be nice to go as low as possible, judging form the previous post 30-35 hz would be a box that I could move. 30-60 hz .... 35- 70hz something like that
Old 6th August 2016, 06:26 PM   #5
a th comes to mind.
400 ltrs you can move it with 2 persones,or 1 when you put casters on?
you can get 121db(mathematical x-max) from 32>80hz +1 -3db @41volt.
. hr driver db
Old 6th October 2016, 02:22 PM   #6
Sorry for disappearing, I was very frustrated and tired.
I decided to use the speaker more like a midbass, built a small box and crossed it at 45 hz. Now I can throw full power at it. Also I am going to write music that moves from 45 hz and on. No more big boxes and crazy adventures
A
Old 6th October 2016, 02:28 PM   #7
These are the speakers, they have a 12 sub and a 12 coax speakers in them
They come with a small powerhouse
jbl gto804 tapped horn/ folded horn 2009thread1 Subwoofers 103 6th December 2015 07:26 PM
Folded horn - volume between subwoofer cone ane th start of the horn benpalmer Subwoofers 8 9th April 2012 02:10 PM
Entering horn meaurements fora folded horn (hornsrep) Tidy Max Software Tools 3 21st February 2011 03:28 AM
Sub with six BMS 12S330 drivers a007udio Subwoofers 4 28th September 2007 06:21 PM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 11:44 PM
Copyright 1999-2017 diyAudio
