Help? SWA1801 Sub quit after 4 seconds - diyAudio
Old 11th July 2016, 09:20 PM   #1
Default Help? SWA1801 Sub quit after 4 seconds
I moved and hadn't turned it on my Mackie SWA1801 powered 18" sub in maybe 3 years. As soon as I powered it on, the LED lights lit up and then there were some slight popping or weird static-y sounds for about 4 seconds and then the lights went off and you could tell it was no longer powered. I unplugged and plugged back in and I can't get her to power on again. I took off the back panel and checked the 3 fuses that I can see and they were all good. I don't see or smell anything that's burnt. The big black transistors(?) don't have domed tops (which would show need for replacement).
Any tips on getting this baby back to work?
I can attach pics if that'd help.
Old 11th July 2016, 09:59 PM   #2
Popping noises are never good, I think you need to get it to a qualified technician this most likely is not something that will be a quick fix.
Need help with Mackie SWA1801 subwoofer amp flyingtele PA Systems 2 28th July 2016 01:23 PM
GONE in 60 SECONDS ODougbo Construction Tips 9 16th October 2013 02:54 PM
Anyone for seconds?????? Dannyball Multi-Way 10 21st June 2004 06:36 PM
What if you want to quit? Bill Fitzpatrick Everything Else 6 23rd July 2002 02:11 AM
Copyright 1999-2017 diyAudio
