Why are Cube Cabinets so popular in Subs? - diyAudio
Old 10th July 2016, 11:41 AM   #1
Philosophil's Avatar
Default Why are Cube Cabinets so popular in Subs?
It seems commonly accepted that cube-shaped cabinets are one of the least desirable cabinet shapes for speakers, and yet it seems to be one of the most common shapes for subwoofers. Are lower frequencies less susceptible to the negative effects of cubed cabinets, or is there something else that would explain why the cube shape is so common in subwoofer cabinets?
Just curious.
Phil
Old 10th July 2016, 11:59 AM   #2
Standing waves develop when the distance between two parallel walls is equal to half a wavelength. For 60 cm that's roughly 280 Hz, well above the crossover point of most subs.
As the distance between two parallel walls becomes smaller, the standing wave frequency increases. Majking it rarely a problem for subs, no matter how many parallel walls a cabinet has.
Best regards
Impossibilities we do immediatly, miracles take slightly longer.
Old 10th July 2016, 12:10 PM   #3
Ron E is online now Ron E  United States
Ron E's Avatar
Also, lowest surface/volume ratio means lowest material costs for a cube.
Interior enclosure shape also matters very little for upper range speakers because of damping material.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 10th July 2016, 12:30 PM   #4
That helps a lot. Thanks.
Phil
Old 10th July 2016, 09:19 PM   #5
Erknie is offline Erknie  Australia
Also it's common to stack two on top of each other for more output, and cube shapes stack well.
Old 10th July 2016, 09:21 PM   #6
Face is offline Face  United States
Face's Avatar
That's old school thinking. That practice does little to help smooth in room bass response.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 10th July 2016, 09:29 PM   #7
diyAudio Member RIP
Its not just standing waves, the walls physical resonances, which
for a speaker you would want to spread about, are also generally
well above the frequency range of the subwoofer, so near cubic
is really the only sensible option for a near optimised sunwoofer.
rgds, sreten.
Mission Freeway drivers - any good for mini-cube subs? Brakspear75 Subwoofers 3 2nd February 2016 09:23 PM
FS Morel drivers, custom CNC machined aluminum cabinets, Dayton cabinets Bronson_k Swap Meet 12 12th July 2015 08:39 PM
Prices on Pensil cabinets and microtower cabinets TWills Planet 10 hifi 9 31st January 2011 02:21 AM
TL subs in the Attic? and Triangular Cabinets ralph-bway Multi-Way 23 16th September 2002 06:22 AM
Copyright 1999-2017 diyAudio
