New Peerless STW350 subwoofer on the horizon...
Old 11th July 2017, 04:48 PM   #11
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
Now that I've seen another magnet geometry pic, I agree that it's a single gap. I went back and looked at my saved photo from a year ago. What isn't clear in that photo is the gap area without a physical picture. What is apparent is that there are 2 magnet structures flanking the long gap, and that is what threw me off. Before it looked like two gaps and a spacer ring, with a single coil. I never said it had 2 coils other than being a DVC architecture. The long coil was longer than what I saw as 'both gaps' before.
Again- agreed that it's just a really long gap and longer coil, and 2 tiered magnet structures flanking the gap.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 12th July 2017, 05:35 AM   #12
bcodemz is offline bcodemz  Canada
The SVS PB16 Ultra uses this driver, or a variant of this. Audioholics has tested this subwoofer outdoors with a ground plane measurement. The maximum distortion limited output capabilities are excellent. In 20Hz tuned mode, 122.9dB at 25Hz with 2.7% THD and 119.8dB at 20Hz with 11.8% THD from 1 meter.
http://www.audioholics.com/subwoofer...r/measurements
Old 12th July 2017, 06:09 AM   #13
GM is offline GM  United States
GM's Avatar
I'm surprised nobody has paid to use Babb's spiderless, ball bearing design to get very high linear Xmax. They were making ~4.5" [IIRC] 'FR' drivers with either 1" or 1.2" Xmax/400 W peak ages ago. Scale that up to a large subwoofer........ The only downside [at least then] was the surround couldn't handle any sort of compression loading, so no BPs or horns.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th July 2017, 07:32 AM   #14
gbullimore is offline gbullimore  United Kingdom
it's an interesting design, but in reality just moves the design burden to the surround,
you still need a given level of restoring force and progressive limit to compliance,
sharing this between spider and surround helps design wise,
Old 12th July 2017, 02:10 PM   #15
Josh Ricci is offline Josh Ricci  United States
Originally Posted by bcodemz View Post
The SVS PB16 Ultra uses this driver, or a variant of this. ]
Correct. SVS marketing says it's an 8" coil but the Peerless literature says it is actually 7.4" diameter.
The smaller top magnet in the motor is used to force more flux through the gap and top plate.
There are some things I like about this driver and some that I don't. For all of that huge coil and heavy ferrite / steel motor it manages a very lackluster qts. It is very inefficient. Great at low sub bass but mediocre at best in the 40-100Hz range where most of the music is. The design lends itself to a NdFeb magnet system but they used ferrite. It almost seems like they designed it for neo and then realized the cost and decided to make ferrite work.
Old 17th July 2017, 03:21 PM   #16
the challenge is actually how to keep the Qts high,
it's easy to find a driver with 0.2 Qt, but as a subwoofer this performs badly in cabinet and requires a lot of electrical compensation . unless of course you use an overly small cabinet and push up the Fs a lot,
the driver was specifically designed to be ferrite from the start,
the combination of Qt suitable for either vented or sealed cabinet, and low Fs whilst maintaining a very low Vas is not easy to achieve,
compare the driver against others in such a small box and see what the performance looks like!
Old 17th July 2017, 04:03 PM   #17
I will have to respectfully disagree.
Keeping Qts high or raising it is easy. Think of it like MPG/KPG in a car. It's not too hard to make an 10 mpg vehicle. Extremely difficult to make a practical 300 mpg car.
Drivers with middle to high Qts and low Vas have been common in car audio for a long time.
Old 17th July 2017, 04:19 PM   #18
I Josh, you are welcome to disagree,
there are other drivers out there that also have high Qt and low Vas, but many of them are not great for home use, they are either too noisy (air noise) very insensitive, or have other issues,
the STW was primarily designed for home audio, and for low distortion, high excursion use in small boxes, there is not much around to compete with it like for like.
and yes, it takes some work to get a low Vas and low Fs, whilst keeping reasonable sensitivity and low distortion, with a manageable Qt,
this driver could easily have been made with a Qt of 0.2 but it would be worse for it!
it's also important not just to rate a driver based on a few numbers on the spec sheet, but to also consider the non-numerical things,
Old 17th July 2017, 05:27 PM   #19
badman is online now badman  United States
badman's Avatar
Agreed. Just weaken the motor, done.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 17th July 2017, 11:47 PM   #20
If you just weaken the motor you have low BL and very low sensitivity.
For a 15" driver with such a low FS and VAS you need a very high Mms which means a strong motor is needed to give reasonable sensitivity.
New Peerless STW350 subwoofer on the horizon...Hide this!Advertise here!
Subwoofer Peerless emisgallo Subwoofers 10 18th June 2013 09:14 PM
Small subwoofer using Peerless 830946 Sumba Subwoofers 15 10th May 2010 05:56 AM
Just ordered my new subwoofer (Peerless) harrisni Subwoofers 57 10th June 2007 11:16 PM
My insane Peerless subwoofer Mikael Abdellah Subwoofers 26 21st February 2006 08:26 AM
Peerless Subwoofer Andy_Mac Subwoofers 26 2nd September 2002 10:18 AM
Resources saved on this page: MySQL 70.00% / PHP 47.96%
