What Type Of Enclousure For Dual 15" Earthquakes?
Old 1st March 2004, 10:13 PM   #1
Tony.ca is offline Tony.ca  Canada
Tony.ca's Avatar
Default What Type Of Enclousure For Dual 15" Earthquakes?
Hi there,
I was looking forward for some suggestions on what kind of enclosure should I build for a pair of 15" earthquake balls for home use, any suggestions welcome.
Thanx,
Tony
Old 1st March 2004, 10:43 PM   #2
officeboy is offline officeboy  United States
Send a message via MSN to officeboy
I take it your previous post didn't help much?http://www.diyaudio.com/forums/showt...threadid=22802
Could you maybe provide a link to these drivers, or the specs on them? Iíve never heard of them and an Internet search doesnít turn much up.
*edit*
I've turned up a little.
http://www.earthquakesound.com/balls121.htm
Might try at the source for your box needs.
Also don't underestimate the easy and usefulness of winISD Especially for a sub box.
Old 1st March 2004, 10:51 PM   #3
Tony.ca's Avatar
I did an enclousure according to their website but it does'nt seem to be as good as it should be. i don't mind trying out transmission line or any other suggestions.
Thanx,
Tony.
Old 1st March 2004, 10:57 PM   #4
BTW, is this home theater use or music?
Old 1st March 2004, 11:09 PM   #5
Tony.ca's Avatar
music
Old 3rd March 2004, 11:52 PM   #6
LineSource is offline LineSource  United States
LineSource's Avatar
Default 5" diameter 13" long port
Tony,
The Earthquake looks like it was designed for very high SPLs at 40Hz. THe 2.5 cu ft "lowest frequency" design on the webpage looks like the best for music. You may want to try a 5" diameter, 13" long port to tune down a few Hz.
You can also consider sealing the box and building a Linkwitz transform to create a controlled Q lower frequency bass boost. This configuration should yield lower and "tighter" bass, but it requires 2x more power.
Music 15" woofers often have lower Mms(100-150 grams), a low Fs near 20 Hz, Qts near 0.35, and are put into much larger cabinets to efficiently reach low freq with good transients.
What Type Of Enclousure For Dual 15" Earthquakes?Hide this!Advertise here!
Harrison type "K4000" (K 4000) MKII 2x1000W/4ohm tiefbassuebertr Solid State 35 15th January 2017 02:46 PM
"BD Pipe"-type speaker using FR125S and WR125S? Brisso57 Full Range 0 6th August 2007 11:20 AM
Aperiodic Enclousure Holty Full Range 16 27th March 2007 08:26 PM
need help on info on DUAL type 260283 10" Full Range Coaxial (german made) eestrera Full Range 1 2nd November 2006 01:28 PM
Membrane to limit "unloading" in ported-type enclosures? Datoyminaytah Multi-Way 6 18th August 2004 05:36 PM
Copyright ©1999-2017 diyAudio
