Help me choose the right driver (4th order bandpass outdoor) - diyAudio
Old 17th May 2016, 06:06 AM   #1
Default Help me choose the right driver (4th order bandpass outdoor)
I would like to build my own garden underground subwoofer in the style of the sononace 12"(LS12ESUB) (4th orde Bandpass).
Subwoofers
I heard it at ISE this year in Amsterdam and I'm impressed!
I have no idea what sub i should use? A car subwoofer or is a marine sub a must?
In my days the brands where Rockford fosgate, JBL, Cerwin Vega, and many more.
What would advice me:
- 12" or 15"?
- What brand/model to fit the use?
- I don't think i have to go very low infrequency maybe 40-45hz?
I will take my existing Rotel wich gives 2x 60w RMS for the satellites and 2 x 150wRMS@8ohms for the sub so DVC is a must.
Thank you
Old 17th May 2016, 08:18 AM   #2
JonSnell Electronic's Avatar
Is it a Volvo-Penta air inlet filter?
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 17th May 2016, 11:09 AM   #3
TBTL is offline TBTL  Germany
Do you have neighbours?
Old 17th May 2016, 02:28 PM   #4
never looked a it that way ;-)
Old 17th May 2016, 02:31 PM   #5
I do but they are fare enough!
here is a section of the sub.
Old 17th May 2016, 07:14 PM   #6
Ron E is offline Ron E  United States
Ron E's Avatar
How big is your garden
what is the furthest place you will listen
what SPL requirements
what are the high frequency speakers?
Designing one of these is nothing terribly hard, you just size the tube for your volume requirements and you make the port large enough in diameter so it sticks out of the ground somewhat. Getting it sealed properly against the elements will be a challenge. You will need some sort of screen on the canopy to keep rodents/insects out.
help for designing bandpass can be found at The Subwoofer DIY Page
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 17th May 2016, 11:09 PM   #7
With that big a tube compared to the front cavity, it's probably best sim'd in HornResp.
The wire mesh to keep out insects should be located as close to the external end of the tube as possible.
It's an interesting idea for an outdoors underground subwoofer. I like it.
www.diysubwoofers.org
Old 18th May 2016, 05:53 AM   #8
Thank you for the answers,
I'm not affraid of the build, i'm just not sure about the driver and box design/size
Here is a little drawing of the garden.
The purpose is to play music only (mostly pop, R&B, reggae, lounge)
The max distance is about 10m
max SPL: no idea how to Judge on that.
the high frequency speakers are sonance satelites 8 pieces (specs attached),
Old 18th May 2016, 05:54 AM   #9
it's indeed a big tube, could it be to limit the air velocity (port noise)?
Old 19th May 2016, 08:56 AM   #10
JL audio.
I have build one
4th Order Bandpass Driver Selection lamsv Subwoofers 15 30th December 2014 10:09 AM
Can you use 2x 4th order BP boxes to imitate a 6th order BP ? RobWells Subwoofers 26 9th March 2012 08:33 PM
10" Driver in the 4th order nonsuchpro Multi-Way 32 19th December 2011 02:03 AM
1st order to 4th order conversion Professor smith Multi-Way 22 28th November 2011 10:41 AM
My 1st order butterworth filter better than 4th order L-R: Why? philipreji Solid State 61 1st March 2007 04:50 PM
Copyright 1999-2017 diyAudio
