Mission Freeway drivers - any good for mini-cube subs? - diyAudio
Old 1st February 2016, 03:10 PM   #1
Default Mission Freeway drivers - any good for mini-cube subs?
I have an old Mission Freeway subwoofer from their long extinct ICE system - this is no longer used but I was wondering if the drive units would be good for making two mini-cube sealed subs for my hi-fi. I've done internet searches on these but drawn a blank on finding any technical specs, so beyond knowing they're 5" drivers I've got nothing to go on - anyone out there know more about them? The photos below show the product numbers and show the sub itself, the drivers were mounted with the rear of both units facing into a small sealed chamber and the fronts into a larger vented one (one drive unit removed in photos).
I also have the freeway plate amp which I can easily build an external 12V supply for and use this to drive the subs if this seems like a viable project to wiser minds than mine... Thanks in advance
Old 2nd February 2016, 09:33 AM   #2
chris661's Avatar
Sounds like they were running a 4th order bandpass.
Without any T/S parameters, probably the most reliable thing you could do with them is put them in a very small sealed box and apply a 12dB/octave boost in the low end. With a pair of 5"s, you'll never shake the room, but you'll end up with a nice compact setup for desktop use.
If you can measure the T/S parameters, or have a measurement setup available, there are more options.
Chris
Old 2nd February 2016, 11:06 AM   #3
Paramètres haut-parleur de THIELE et SMALL, sans filtre ni ampli
Old 2nd February 2016, 09:23 PM   #4
Wow, thanks for those data, Papasteack. I've had a quick look at them and also downloaded Boxsim and had a play with the figures, but I've never built any kind of speaker before so I may well be returning with more questions when I've had a chance to think about this in more detail.
Mission "M-Cube" help RS232 Subwoofers 21 27th October 2016 05:57 AM
FS: Ditton 22 drivers,BW tweets,Heybrook tweets,Grilles,Mission drivers,Pioneer amps aulday Swap Meet 0 8th April 2015 10:41 PM
Cube Audio Horns & Fullrange Drivers CubeAudio Vendor's Bazaar 0 22nd September 2012 05:30 PM
Mini slim tour help for good drivers oaristys Multi-Way 24 28th June 2009 02:03 AM
Cube-shaped sub right in the corner with drivers on left, right and top. Circlotron Multi-Way 1 16th September 2002 09:28 AM
Copyright ©1999-2017 diyAudio
