Like the K-horn, this design doesn't appear to do much below 40Hz. Definitely a challenge to build Would it do any better than a similarly-sized bandpass or ported placed in a corner is the question. If you made a cubical box that took up the same space you could probably easily fit 20 cubic feet (~600 Liters), which would allow several high sensitivity pro drivers to hit 30-35Hz easily. With 4x JBL 2235 or similar you might even hit 20 or below...
