How many subs can be driven with a single mono amp? - diyAudio
Old 7th January 2016, 04:08 AM   #1
Rob41 is offline Rob41  United States
Rob41's Avatar
Default How many subs can be driven with a single mono amp?
Sorry if this has been covered elsewhere but I have been unable to find a clear answer.
Without getting too technical, how many subs can I drive with a single mono amp?
This is for a home audio system employing a summed signal distributed bass system 70-75Hz and below.
I plan to use 4 enclosures each housing two 15" Dayton subs so there will be 8 subs.
I can use 2 mono amps if necessary. The driver I plan to use is this:
Dayton Audio RSS390HF-4 15" Reference HF Subwoofer 4 Ohm
Thanks in advance,
Rob
MiniDSP 4x10/Nikko Alpha 650/SAE 2600/SAE 2400/Soundcraftsmen MA5002/Heathkit AA-1800/Heathkit AA-1600
Old 7th January 2016, 04:45 AM   #2
depends on the minimum impedance your amp can handle and how much power it can supply before clipping imo
Old 7th January 2016, 05:00 AM   #3
infinia is offline infinia  United States
infinia's Avatar
depends on the amp and SPL levels expected , target 8 ohms nominal for a home grade amp and 4 ohms for a pro grade. so 2 subs in series for 8 ohms per box and 4 subs total in series parallel combination giving 4 ohms for the pro grade E.g. use 2 boxes in parallel.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 7th January 2016, 05:03 AM   #4
Rob41's Avatar
I'd be using eight 4 ohm drivers in series/parallel to end up with to end up with a 4 ohm load.
I think the power I can supply may be the determining factor and with these drivers power handling capabilities I think I'm going to need more amps.
Old 7th January 2016, 05:06 AM   #5
Rob41's Avatar
Right, I think I'll be okay if I use two Crown Xti 4002 amps. Perhaps 4 in the Xls line run mono would be a better fit to provide more headroom. I only need a max of around 105db on peaks so any of it would likely be overkill but I'm okay with that.
Old 7th January 2016, 05:12 AM   #6
infinia's Avatar
yes Crown is a pro name brand
Old 7th January 2016, 05:17 AM   #7
Rob41's Avatar
I don't have the skills to build my own amps and something like the Crown amps would be within my price range.
I use a Nikko Alpha 650 to drive my bass right now which would not be enough for what I'm planning.
I use a Heathkit AA-1800 and a Heathkit AA-1600 with a MiniDSP to drive a pair of open baffle line array's I built.
Old 7th January 2016, 05:27 AM   #8
Using series-parallel connections the only upper limit to the number of subs is your sanity. You can keep the impedance the same.
With 8 4ohm subs your practical impedance options are 8 or 2 ohm. I'm not seeing how you can end up with a 4 ohm load. Pretty sure you cant.
Old 7th January 2016, 05:31 AM   #9
Rob41's Avatar
Thanks for the heads up on my miscalculations. Looks like I'll be going with 8 ohms.
It's not for HT and I don't need it to be insanely loud. Just accurate and evenly distributed. Perhaps I should consider scaling down to 12" drivers.
Old 7th January 2016, 05:35 AM   #10
Yes, you're buying quite the load of displacement, and doesn't sound like you're trying to fill an auditorium. I'd vote going to 4 cabinets of 15's rather than 4 cabinets of 2x12. Back to 4 ohms.
Happy DIYing, Daniel
Bi-amp for single mono speaker? Tim Young Multi-Way 13 31st January 2015 05:21 AM
Running two LM1875 mono amp from single psu si82 Chip Amps 21 2nd June 2014 04:32 PM
Horn build recommendation for a Mono,Vinyl, Hi-Fi, Tube driven DJ. dwade277 Full Range 30 31st July 2012 08:24 AM
Help needed: hum noise in Eimac 250TL driven by 75TL Single End Amplifier HP8903B Tubes / Valves 8 5th May 2012 12:41 AM
Single or double transformers for dual mono amp? Bernie7 Class D 1 30th December 2008 02:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
