Multiple subs vs. bass traps
Old 23rd January 2016, 02:16 PM   #171
Joel Wesseling is offline Joel Wesseling  Canada
Ten Million dollar anechoic chamber
https://uwaterloo.ca/news/news/next-...facility-opens
Old 23rd January 2016, 02:38 PM   #172
bentoronto is online now bentoronto  Canada
No radio-wave echoes! Instructive to consider that those radio wavelengths can be just fractions of an inch as compared to 50+ feet for sub-sonics. Not sure why you'd need any chamber, except to keep out of the Canadian winter weather. Maybe real function is as an isolation chamber, a very different issue.
Even mighty Harman Corp's anechoic chamber didn't/doesn't go very low and needed math tricks to estimate low frequency performance, if I read Toole correctly.
Few truly big-scale anechoic chambers like the biggie at Bell Labs in Murray Hill, NJ, where I fiddled with motional feedback 45 yrs ago. I'm not sure how low that went. Anybody? Or the EMI building??
Do you need to vacuum-clean an anechoic chamber every decade?
Ben
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and just posted data for a folded 17-foot pipe sub)
Old 25th January 2016, 05:31 PM   #173
youknowyou is offline youknowyou  Canada
youknowyou's Avatar
Originally Posted by bentoronto View Post
Depends on a lot of factors. If you are doing serious construction, it costs only a bit more than the drywall it is substituting for and might need no finishing, unlike drywall. And that's it.
Ben
if you were to build the walls, why not use a couple of feet of fluffy rockwool which will work 10 times better.
Dad's speakers: Amphion one18/ Genelec 1037b/ ESL57/ Altec604/ Tannoy RED 15 inch/
Mine: Harbeth SHL5+
Old 2nd January 2018, 12:53 PM   #174
jpak is offline jpak  United States
jpak's Avatar
One of the more interesting approaches I have read about is Welti's method of just using two subwoofers (pretty sure this AES paper is freely available), one placed mid front wall and the other mid rear wall to "destruct" room modes. Any thoughts on this vs everything else discussed here?
Old 14th January 2018, 02:42 PM   #175
JonFo is offline JonFo  United States
I use that method in my theater. The front Sub is 4x15 IB with the manifold in-room. The rear sub is a 16 cuft sealed sub with a 18" Dayton Ultimax powered by a Crown XLS2500 (bridged).
There was significant improvement in the smoothness throughout the space, and FR at the MLP improved. With just the IB, there was a big null at 20 and 76Hz, now smooth at 20 and much improved at both points now.
Here is the waterfall plot, measured at the MLP, it reflects my house curve EQ, which is why the <80Hz rises.
Room was ideally sized, and then extensively treated. Subjective bass is very smooth and clear. And that IB goes deep, shakes the whole structure, the door will occasionally pop open due to pressure and vibration releasing the latch!
But more importantly, music is crystal clear even at high SPL.
I do plan to add another 16cuFt sealed (identical to the rear unit) at roughly the mid-point sidewall location, almost parallel to the MLP. as a way of further smoothing some of the resonances at 27 and 41Hz.
Jonathan
Old 14th January 2018, 07:22 PM   #176
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
I've just read the whole thread, if you don't want to do that, start at post #104
This is very interesting stuff. I want to ask whether this method also means the room is not pressurised? It seems to
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 20th January 2018, 09:31 PM   #177
jpak's Avatar
Do you think there are any downsides to doing this with a stereo system opposed to home theater?
Old 20th January 2018, 10:32 PM   #178
Alone among "suspensions", sealed boxes provide negative feedback, assuming the air is more linear than the starched fabric or bubbly foam rubber holding the cone in place.
B.
Old 21st January 2018, 12:40 AM   #179
jpak's Avatar
Can expand on what you mean by "room is not pressurized"?
Welti's method basically uses the second sub on the back wall to "destruct" the room modes since it is playing out of phase. I have seen measurements from one other system that does this (along with many RPG Modex plates) and the response is incredibly flat and the user says bass response is very even throughout the room.
Full paper is here: https://audioroundtable.com/misc/Welti_Multisub.pdf
Old 21st January 2018, 08:27 AM   #180
Two sealed subs, one phase reversed is a dipole and so theoretically won't pressurise the room. This link explains it DP_woofer_room
Multiple subs vs. bass trapsHide this!Advertise here!
What is the diff between distributed subs and lots of bass traps??? djn Subwoofers 22 27th December 2015 08:57 PM
Bass traps? simpleacoustic Subwoofers 7 30th November 2011 11:29 PM
When and how to use bass traps MalJ Multi-Way 5 15th September 2010 12:40 PM
DBA (dual bass arrays) and active bass traps capslock Subwoofers 3 20th August 2006 12:52 PM
bass traps? bostonswoop Subwoofers 3 30th March 2006 02:03 PM
