Subwoofer problem (Farting sound, loose screws and frontal air) - diyAudio
Old 10th November 2015, 09:39 PM   #1
Default Subwoofer problem (Farting sound, loose screws and frontal air)
I got a relatively good sub from my friend. Problem is... it's in shitty condition. It's Magnat Killer Bull 300x (250w 12inch 4ohm). It got several problems...
1. Dust cap has fallen of and it has been "reglued" with wide insolation ducttape - there is no dust inside but I don't know how to remove the ducttape without destroying the speaker so I can reglue it properly as I doubt that ducttape fix will last
2. One or two screws are loose so you can hear them unless i put some pressure on them with my fingers
3. I can feel the air from the front of the speakers.
It sound really good until about 60% loudness. Is there any hope for such speaker?
Old 10th November 2015, 11:02 PM   #2
Well, the duct tape is an issue, it increases the weight of the cone and changes the tuning a little.
Loose screws and air leakage is pretty easily fixed. If the screws are simply wood screws and are stripped out, you can treat them as any wood screw, and use toothpicks or match sticks with glue to repair the holes.
If the screws are "machine screws", and should be screwed into something like a "t-nut", but those have dropped off, you will want to pull all the screws and ease the driver out and investigate what the problem is. That all should be easy to fix.
I'd be tempted to simply leave the duct tape there, and as it starts loosing the adhesive, cut the loose parts away...
Old 11th November 2015, 11:19 AM   #3
dannyjmf's Avatar
better to fix the dustcap problem using superglue ... it will hold up stronger compared to duct tape ... and regarding the air from the front of the speakers, it might be air leaking around the woofer area ... sealing the area with double sided foam tape will do the trick ... which is what i always do ...
Old 11th November 2015, 12:22 PM   #4
SS4927 is offline SS4927  Canada
SS4927's Avatar
If screws strip out Ill usually remove them all and rotate the driver an inch or two. Then make fresh holes. Dont forget to drill pilot holes otherwise you will have other problems with cracking. Order this for the dust cap Speaker Repair Adhesive, Dust Caps, Lead-Wires, MI-2000
Quad ESL63 Holes for screws in mebrame make sound ? WrineX Planars & Exotics 16 27th February 2015 09:31 AM
I got loose screws qguy Subwoofers 18 12th August 2011 03:02 AM
Help me stop my preamp from farting! Buckeye Sound Tubes / Valves 14 26th October 2005 02:21 AM
amp crackling/farting? twizza Solid State 3 16th March 2005 06:45 AM
need good drivers for frontal and central speakers. samsagaz Multi-Way 0 24th September 2004 01:26 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
