Some facts:
This driver is good in a sealed config. also.
Tquaterwaves also: You should ask somebody to design it, if you like, has good behaviour.
What RMS power for a reference. (PA's or home.)
Yes it will have a better extension in low frq. than JBL and -2dB in sealed versus -5dB@50Hz JBL reflex, as a reference only.
It will be a full 100% sub, as I understand but you can take advantage of LTransforms for the reduction of the total volume (<100/85 liters). You can simulate both designs, to see direction for the final project. Driver goes very low but needs extra vol. 3/4 times bigger than JBL reflex.
As a note look at the thread: Optimum net volume for tapped horns by Petter Persson (reverse engineering of Tom Danley article). Have fun.
Frequency graph
There cut off at 80-90hz
So domt care about much after that
I realize they are not as sensitive as some drivers below 35hz but well give them a go..
I am sure there better than my jbl 2240 ive had since 1998《♥♥♥》
frequencygraph is basically meaningless for sub design.
All in the T/S specs.
- Subwoofers
- Double 18 with Precision Device PD186 build
