Plate amp installation - diyAudio
Old 21st August 2015, 08:43 PM   #1
Default Plate amp installation
I have two beautiful AV123 MFW-15 subs but they were made with lousy amps and the company is no longer in business. Can I (or would it make sense) to replace these with plate amps ( Yung SD500-6 ?) ? How difficult would it be. I am a retired mech engineer with good wood working skills but really fall short with electronic smarts. I have, though, over the years learned to successfully change a light bulb. If this would be a simple job of removing the old amps, cutting the back panel to fit the new plate dims, then "plug and play" I can do that. If it requires a lot of changing or replacing electronic components would probably screw things. Would I be biting off more than I can chew with this project?
Any comments or advice would be sincerely appreciated.
Old 21st August 2015, 10:54 PM   #2
Inductor's Avatar
I don't know but some subs have LTs and equalization. Does the old priginal amp have any? Some other members are more acknowledgeable.
Old 21st August 2015, 11:03 PM   #3
taloyd is offline taloyd  United States
Post FYI
From pictures I've seen (this is a very common problem) there is a separate sealed chamber for the plate amp - so at least you don't have to worry about an airtight fit - just that the new plate amp physically fits. An option is to simply build a small box for the Yung plate amplifier and have a short umbilical cable connecting them.
Tal
ps: if you have two of them I'd just use a pro-sound amplifier, but one without fans. The Crown K1/K2 are perfect for that, but hard to find.
Amp Installation Help Dregun Car Audio 5 9th July 2010 04:08 AM
Question on the installation of LL1668 plate choke Ruach Tubes / Valves 3 27th October 2006 04:23 PM
DIY Plate Amp --> Need the Plate!!! gmikol Parts 4 17th February 2006 08:20 PM
Amp installation accvtec Car Audio 6 21st April 2004 04:57 AM
amp installation help slarty43 Car Audio 1 20th February 2004 02:42 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
