B&C 18" Driver Advice - diyAudio
Old 27th July 2015, 07:27 PM   #1
bjones is offline bjones  United States
Default B&C 18" Driver Advice
Hello all,
I THINK I have narrowed down driver selection to 2 models:
18PS100 & 18TBX100
I am planning to build 2 single 18" BR enclosures to be used outdoors at this year's Burning Man for a camp size of about 750sq.ft.
T/S wise - to my novice eyes, it seems that I can build an enclosure for the PS100 tuned at 29hz while the BX100 enclosures I see are tuned quit a bit higher. We want these subs to go as low as possible without compromising more SPL than necessary. The goal would be 30hz as the ideal LFE.
Power wise we are looking at a Crown CE2000 amp to drive both.
Can anyone shed some light for me on this?
Old 27th July 2015, 09:51 PM   #2
ErnieM is offline ErnieM  United States
18TBW100 all day.
Old 27th July 2015, 09:53 PM   #3
Originally Posted by bjones View Post
Hello all,
18PS100 & 18TBX100
Bennett Prescott has:
https://soundforums.net/threads/12058-B-amp-C-18rbx100
The RBX100 should just about be available now, and appears to have more displacement than the 18TBX100 (for less $$), and quite a bit more than the 18PS100.
The 18PS100 will go a bit (4-5 Hz)lower, require a larger box, but won't go as loud as the other two choices. For what you want to do, louder usually wins.
Art
Old 27th July 2015, 10:06 PM   #4
Originally Posted by ErnieM View Post
18TBW100 all day.
Can you expand on this a little for me? The cost is approximately 45% higher, if you could explain your reasoning it would be greatly appreciated.
Old 27th July 2015, 10:17 PM   #5
Art
Thank you Art,
Bennett informed me that the RBX would not be available for this years Burning Man ( Aug.30) So I am left with the other choices. Per B&C site it looks like the req. tuning is exactly 5hz appart 29 vs 34. If you believe from your experience that the SPL increase using the slightly higher tuning of the TBX is a worthy compromise, I think this is the route I will choose.
Old 27th July 2015, 11:34 PM   #6
Is pack space an issue? A horn (tapped or flh) or bandpass can get you higher SPL levels for the same number of drivers and amps. Just needs lager enclosures.
What kind of music are you playing? 30hz is a really low target for outdoors. Even moving the target to 35 will get you appreciable sensitivity gains, which tends to be the real winner in applications like this.
Also relevant, what tops are you crossing to and at what frequency?
Old 28th July 2015, 12:13 AM   #7
Tajzmaj is offline Tajzmaj  Slovenia
I'm using TBW units in double 18'' br. It is nice sounding and well built. I'm driving those with Carver PT2400. I would say it is definitely worth the price.
Cheers
Old 28th July 2015, 12:36 AM   #8
It's just a more capable driver. I bought four B&C 18PS76's a couple years ago. They work well for most of my needs but after experiencing where the rest of the money has gone that could've got better drivers....well....I would've rather splurged once for the nicer drivers. Especially important if you only plan on using a couple boxes. Also look at the keystone sub.
If you want to save money look at PRV audio for their TBX clone. Shoot for a 35-40hz tuning. Getting low and loud requires a lot more cash and space.
Old 28th July 2015, 02:36 AM   #9
sine143 is offline sine143  United States
For bass reflex down to the lower 30s the tbw100 is pretty much the "clear choice". The more substantial xmax gives you the displacement you need to stay within the limits above tuning when tuned low. It takes a Lil hit in sensitivity though.
Old 28th July 2015, 04:15 AM   #10
Thank you all.
I'll buy once and go with the TBW.
FYI the subwoofers that we have: JBL MP418SP
So that's what I need to beat with this build (hopefully noticeably)
And the subwoofers they wanted to get but were cost prohibitive at the time:electrovoice EKX18sp so if I can get to around this level I think they will be pleased.
The mains are:JBL MP415 M-Pro
Need advice on an 18" driver Egindin Subwoofers 7 29th July 2015 06:49 PM
Tannoy Kingdom 18 replica, which 18" bass driver? EricFr Multi-Way 9 12th October 2014 10:32 PM
Scaling up the SS15 for an 18" driver and other compact 18" designs col Subwoofers 32 23rd January 2012 10:17 PM
seek advice on enclosure for 18" subwofer joekjtam Subwoofers 1 10th January 2005 04:19 PM
EAW 18" driver specs Graydon Subwoofers 26 7th November 2004 02:43 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
