RCFLF21N451 - diyAudio
Old 27th June 2015, 10:50 PM   #1
Default RCFLF21N451
Anyone have much experience with this driver?
It seems like a steal compared to B&C offerings.
RCF :: RCF LF21N451 1500W AES 21" Driver 8 Ohm 221.22 Excl VAT
Old 28th June 2015, 12:48 AM   #2
GM is offline GM  United States
GM's Avatar
Sheesh! 130 dB in the mid-bass out of a 3.5 ft^3/42 Hz box + 12" dia. vent and if WinISD is correct, not even exceed Xmax at a 230 degF VC heat rise.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 28th June 2015, 01:19 PM   #3
I wouldn't waste this in a 3.5 cubic foot box.
Old 28th June 2015, 01:27 PM   #4
And if you're at a wedding and they want you to set up in a corner for neatness, you can shake the bride and groom with 120dB of bass down to below 35Hz 10m away from the DJ - until they ask you to turn it down!
If you go with a superior design to the boring old vented cab - even better. Maybe an OThorn or a widened version of JBell's tapped horns.
Old 28th June 2015, 02:02 PM   #5
chris661's Avatar
I picked up the P-Audio 21" neo driver at the Blue Aran clearance sale. A bit cheaper than the one you're looking at, slightly less Xmax, but 1800w power handling.
I'm simulating a constant-taper variation of a TH (T-QWT?), with the cross-sectional area set as 1400cm^2.
A single-fold design going from floor to ceiling would give a footprint of around 600x430mm (plus wood thicknesses), and a 3.5m path length tunes around 20Hz for a HT monster - ~130dB to 20Hz if you stick it in a corner.
This is with just 50v RMS input, so you'll need around 400w into 8ohm. Power compression will be minimal.
Haven't decided if I want this for PA or bonkers HT, though. 21"s are rather big to be moving anywhere without a van.
Chris
Old 28th June 2015, 02:19 PM   #6
GM's Avatar
I merely noted its performance potential, but it all depends on the needs of the intended app as to whether it's a 'waste' or not...........
GM
Old 28th June 2015, 03:16 PM   #7
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi All,
FYI:
b
Old Yesterday, 08:05 PM   #8
That's a good chart. I amended the Hornresp sims, though the response didn't change that much.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
