Driving 300w dvc woofer with 6 watts
Especially at 89db 1w/1m. Spec sheet also shows 100w NOT 600w...
Yeah I see that, but it doesnt matter to me haha.
Since its 100 watts do you think 6 watts to each coil will be fine. I dont need much at all, it is going to be in a mini boom box so it doesnt have to be that great. It will be wired in parallel with my full range drivers that will each be recieving 6 watts of power
Administrator
Joined 2004
89dB +/- 3dB means 86dB.
Careful your amp can handle a 2 ohm load or consider using a high pass filter on the FR drivers.
Touche' Cal. Can't imagine a 6w PS handling 2ohms.
DVC but 8ohms: Goldwood GW-406D 6-1/2" Poly DVC Subwoofer Shielded
I like this one (efficiency nut) : Pyramid W64 6-1/2" Pro Plus Midbass Woofer
I recall Art Welter describing a pseudo mono summation method by wiring positive of left channel and negative of right channel to driver.
All this being said, just got this little dude: Amazon.com: Behringer EUROPORT MPA40BT All-In-One Portable PA System with Full Bluetooth Connectivity: Musical Instruments. INCREDIBLE jam box. I am getting more than 12 hours before a recharge. DJing a graduation party with it tonight, taking it with me golfing and doing awards ceremony after. Building a sub for it soon...
Well I'll be darned, it'll take 2ohms... Just looked at a few boards with this chip on ebay for an amp for the aforementioned sub. I'm aiming 100-200w with a XO board. Used it before? Just curious if the stuff is legit.
You might have more options if you step up to 8" and get lower F3 too?
Use a crossover, and you'll also want to isolate it from the midrange speakers in a separate enclosure so it doesn't pressurize their cones and get them moving.
With a passive crossover you might be better off with a higher crossover frequency like 300Hz to keep the parts smaller compared to a 100Hz which would be better with separate amps.
On another note, that thing would make a mean mini tapped horn.
