Acoustic Lens = Karlson etc ?
Old 21st June 2015, 04:24 AM   #1
Zero D is offline Zero D  United Kingdom
Lightbulb Acoustic Lens = Karlson etc ?
Att. freddi et al
Hi, i thought you might find this interesting. I see some similarities between the two.
High frequency power dispersion and amplitude response
1. "The power response should be as flat and smooth as possible relative to the free field frequency response
2. "Strong floor and ceiling reflections should be avoided
3. "Strong reflection off the wall directly behind the loudspeaker should be avoided"[8]
The device that is used to accomplish this is called an “Acoustic Lens.” It is a scalable reflecting device that fits over a conventional treble dome tweeter or mid-range driver, which is facing upwards. It was invented by Manny LaCarrubba of Sausalito Audio Works, and is licensed to Bang & Olufsen
Moulton Laboratories :: A new loudspeaker design
The Acoustic Lens
The effect of the lens is to distribute energy emitted from the driver (which is facing upward) across 180 horizontally and approximately 30 vertically (angled approximately 15 upwards). Other properties of the lens permit the lower crossover point of the driver to be lowered in frequency, extending the effective range of the driver and permitting the relative directivity of the two drivers at the crossover frequency to be evenly matched.
Wonder how they got a patent, "if" it's not actually totally new ?
Old 21st June 2015, 04:52 PM   #2
freddi is offline freddi  United States
freddi's Avatar
looked at those for years and Paterick Bateman's YouTube videos - another useful lens would be the old slot tweeter type such as the discontinued Selenium ST320 - it was quite even in the horizontal plane http://www.selenium.com.br/sitenovo/...os/ST320_p.pdf
Old 21st June 2015, 10:45 PM   #3
@ freddi
That's a slot tweeter, which seems like a different concept ? Fane used to make them, & a bullit version too. I installed a number of them over the years into various systems. The slot was about 110dB & the bullit about 112dB @ 1W. The slot was a bit smoother sounding, but both were good, if xovered correctly & not over driven ! None ever burnt out. Pity they don't make them anymore.
Old 21st June 2015, 11:36 PM   #4
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Sausalito Audio Works (SAW) acoustic lens is very different than Karlson aperture. It's for high frequency and acts as both a reflector optic like an off axis parabola and a diffraction lens at same time. K aperture really does provide some amazing wide dispersion. My measurements of polars of a driver behind a K aperture such as in the XKi or the Kazba are truly amazing. However, the K aperture will introduce dips and coloration. However it is not offensive.
http://www.diyaudio.com/forums/full-...-bandpass.html
http://www.diyaudio.com/forums/full-...le-dipole.html
Old 24th June 2015, 11:42 AM   #5
@ xrk971
Hi & thanx for posting. I realise the SAW designs are HF & reflectors etc. I just thought that the shape of the openings were similar, & if enlarged & placed over a bigger driver, it would more or less equate to a K type design, in that respect anyway.
Old 24th June 2015, 07:50 PM   #6
freddi's Avatar
I've love to try that lens but can't make the shallow 1/4 ellipse cavity in a good way. That cavity's depth is about 1/2 of the diaphragm's diameter - Patrick Bateman's rough mockups sound very good. Here's an old related patent
(reminds me of a urinal )
https://docs.google.com/viewer?url=p.../US2643727.pdf
Old 24th June 2015, 09:52 PM   #7
@ freddi
1950 ! Another very old invention that got rediscovered etc
Old 25th June 2015, 02:45 AM   #8
freddi's Avatar
the basic idea goes back further - but 1927 is recognizable in function
https://www.google.com/patents/US1786279
Old 26th June 2015, 06:13 AM   #9
@ freddi
Amazing ! That was also reinvented in later years too
Acoustic Lens = Karlson etc ?Hide this!Advertise here!
Enhanced L91 Acoustic Lens for JBL / Selenium / PRV WG14-25 (1"), WG14-50 (2") Horn. TomHinton Swap Meet 1 5th January 2015 07:24 PM
Acoustic Lens whgeiger Multi-Way 3 12th December 2011 11:13 AM
Karlson HF waveguide tweeter lens freddi Multi-Way 0 22nd August 2007 01:12 PM
Helper tweeter lens via ~Karlson idea "THE KUP" freddi Full Range 0 25th November 2006 06:54 PM
DIY acoustic lens jmikes Multi-Way 1 13th January 2005 11:12 PM
