running subs in series -side affects?
Old 13th June 2015, 04:09 PM   #1
JimBanville is offline JimBanville  United States
Default running subs in series -side affects?
I have 2 identical unmarked 12" sub single voice coil drivers in sealed 2 cu ft boxes. Passive subs. They have an odd impedance. Either 3 or 6. Lost the email from the manufacturer. I'll try to get that info again. Anyway, they are for my home theater. I have a BASH 300 watt plate amp from parts express. Driving one of these woofers with the BASH, I'm getting "matching" levels from it using receiver test tones (mains and sub are at 0db in receiver) with the BASH volume knob at 1/3.
Here's the question... If I wanted to "test" running the two passive subs (placed beside each other) in series from the single BASH amp, would there be any affect on the frequency response from the woofers due to changes in T/S parameters?
Also, my understanding is that due to doubling the impedance, the amp will put out 1/2 less power, but since it's going to two 12" woofers (twice the radiating surface versus one 12") the volume level I'm hearing now shouldn't change much, even if leaving current amp volume knob at 1/3. Correct? My idea is that I may get more headroom and less distortion from two subs vs one.
Thanks!!
Old 13th June 2015, 04:19 PM   #2
jplesset is offline jplesset  United States
I've personally voted for multiple subs, currently running 4 10". Series is fine, no worries. Since my subs are 4 ohm, I run two in series on each channel of my amp.
Old 13th June 2015, 04:29 PM   #3
Thanks. But in your situation, the amp is still seeing the a 4 ohm load.
My questions are-
1- since using 2 subs vs 1, will current volume level I hear with volume setting of 1/3 change? Amp is putting out less power but to twice the radiating surface area.
2- will running the subs in parallel change their T/S parameters and change their frequency responses with them being in the properly sized sealed boxes for being run individually now?
Old 13th June 2015, 04:33 PM   #4
R.I.P.
The volume will be identical. The parameters won't change.
Separate spacing is probably a good idea for smoother bass.
1/3 along the rear wall and a 1/3 down the opposite side wall.
The amplifier should be fine with two 6 ohm subs in parallel.
If they are 3 ohm best used in series. Might be worth looking
at the bass boost options for your sealed boxes :
http://www.parts-express.com/pedocs/...tion-guide.pdf
rgds, sreten.
Old 13th June 2015, 04:35 PM   #5
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
You can have a look at usual theoretical calculation regarding Qe, Qm, Qt.
Old 13th June 2015, 04:41 PM   #6
Um, no. Two woofers in series for each channel of a stereo amp, as stated....
Old 13th June 2015, 04:52 PM   #7
I only half read your post. I thought u wrote u ran each pair in series and then ran those 2 pairs in parallel. Sorry.
Old 13th June 2015, 04:54 PM   #8
rgds, sreten.
Thank u very much! I'll try it out tonight.
running subs in series -side affects?Hide this!Advertise here!
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 38 20th February 2014 12:16 AM
Running two different subs? mr. doom Subwoofers 5 27th February 2011 09:18 PM
anyone running RE subs? skooter Car Audio 6 23rd November 2008 05:35 PM
My GC is up and running, side by side with P3A Jean Chip Amps 2 21st July 2004 11:38 AM
implementing side-firing subs into towers bonsai171 Multi-Way 1 25th February 2004 04:14 AM
Copyright ©1999-2017 diyAudio
