who can tell me best way to wire my subs - diyAudio
Old 21st April 2015, 09:40 AM   #1
Default who can tell me best way to wire my subs
i have two 4 ohm subs and a 1000 watt two channel bridgeable 2 ohm stereo stable amp. can i wire the subs parallel, and if so, can i wire them using the bridged way on the amp. or how would you recommend i wire them up to get the most out of the subs and amp. thanks.
Old 21st April 2015, 11:01 AM   #2
Sub 1 -> Channel 1
Sub 2 -> Channel 2
If the amp is stable down to 2 Ohms in Stereo mode, it will probably be stable down to 4 Ohms in bridged mode.
Old 22nd April 2015, 05:33 AM   #3
so i can take both (+) from both subs and connect them to channel 1 positive post and take both (-) from both subs and connect them to channel 2 negative on the amp
Old 22nd April 2015, 05:39 AM   #4
or can i wire them in series and bridged at the amp
Old 22nd April 2015, 08:02 AM   #5
You could operate them in in series in bridged mode, but I see no benefit to connecting them each to their own channel. Don't operate them parallel in bridged mode though for the abovementioned reason.
diy >50' rca cable for subs using speaker wire: yay or nay? Count Sudoku Parts 10 3rd June 2014 08:57 AM
Multiple-Small-Subs vs A-Few-Large-Subs Eskae Subwoofers 11 21st August 2013 08:17 PM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 12:44 AM
2 subs one box/2 subs 2 boxes vetkilr Subwoofers 5 22nd February 2006 09:27 PM
help me wire my subs parki59 Car Audio 6 15th April 2005 10:47 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
