Marty Cube with Dayton spa1000 plate amp? - diyAudio
Old 13th April 2015, 08:10 AM   #1
Default Marty Cube with Dayton spa1000 plate amp?
Hello Forum......I have been surfing a lot of sub-threads......I am now going to attempt a MartyCube build.
I have seen a lot of threads and photos of other projects.....all seem to have external amplifiction. I would like to build a plate amp into my unit.
Here are my measurements.....inches converted to cm.
4X 61x61....top, bottom, sides.
1X 61x57.....back.
3X 61x50.....2xfront baffle, brace.
1x 61x54....port bottom.
1x 61x45.....port back.
2X 5x54.......bottom rails.
2X 5x52.......back rails.
I hope the above measurements are ok. I will use 19mm MDF.
Dayton 18" Ultimax will go in.
How would I mount the spa1000 amp best? On the side? Has anybody mounted a plate amp in a MartyCube?
Any info would be good.
Old 16th April 2015, 07:07 AM   #2
I would like to mount the plate amp on the back. I will of course have to cut a hole 10"x10".
My intentions are to separate the vent-rails by 10"...... Cut the hole and install......
Will this affect the performance of the sub?
Has anybody done something similar?
Old 16th April 2015, 11:46 AM   #3
Won't you be blocking part of the vent if you do that?
If you block the vent, that will change Fb, which in turn may produce less than optimal results.
www.diysubwoofers.org
Old 16th April 2015, 01:51 PM   #4
That is exactly my question. The vent wont be totally blocked though.......slight mod possible......I guess..........
The back vent board will be cut in a U-shape......permitting venting under the amp.....will this work?
Dayton SPA1000 plate amp reliable? anderslober Subwoofers 0 8th April 2015 07:15 AM
Dayton plate amp powering with DC dimuthu44 Subwoofers 4 15th September 2014 09:52 PM
Dayton SA240 plate Amp@ 240Volts? webby Subwoofers 8 2nd August 2013 12:55 PM
WTB DAYTON 240B PLATE AMP codes1 Swap Meet 0 19th April 2011 11:05 PM
Anyone own the Dayton Black Cube speakers? Will this receiver overpower them? kehi Multi-Way 1 14th December 2003 11:53 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
