Can I make a small subwoofer from 2 no-name 6 inch woofers? - diyAudio
Old 11th April 2015, 02:30 PM   #1
Default Can I make a small subwoofer from 2 no-name 6 inch woofers?
So I have two pipe speakers as seen here: PVC pipe speakers
And I also have two 6 inch woofers from a set of AIWA speakers. I have no specs of them, other than their 6 ohm impedance. But they deliver decent bass and I want to put them to use.
Could I use them both in a sub box to complement the pipes? How can I approximate the dimensions of the box and how should I mount them?
Old 15th April 2015, 03:47 AM   #2
dannyjmf's Avatar
U can follow this link and measure the T/S parameters for your woofers ... Post the parameters here so it will be more easy for me to give u some suggestions
The Subwoofer DIY Page - Measurements
Old 15th April 2015, 04:19 AM   #3
I would hesitate to call anything using recyled 6" Aiwa woofers a "subwoofer" no matter how many you use. But, sure, you can re-use them in a new speaker.
"Hardware eventually fails. Software eventually works" - Michael Hartung
13 inch Seas woofers H175 33F-ZBX/DD woofers brand new in the box josemedeiros Swap Meet 2 30th January 2015 12:19 AM
Hypothetical question on multiple Small woofers vs few larger woofers navin Multi-Way 38 7th June 2010 11:17 AM
Four Inch Woofers Have 10 jagster Swap Meet 0 18th April 2008 04:11 PM
5 inch woofers homertooties Multi-Way 4 20th November 2005 05:45 PM
Small Woofers For A Subwoofer? kspv Subwoofers 16 9th May 2004 10:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
