Need help wiring DVC AE Dipole 15 - diyAudio
Old 24th March 2015, 10:49 PM   #1
Default Need help wiring DVC AE Dipole 15
I have a pair of AE Dipole 15 (-8) mounted in a u-frame and am ready to try them out for the first time, but I'm not confident I know all the possible wiring scenarios and the results each would net. Each vc measures 6.3 ohm.
If I wire one channel of the amp to either of one set of terminals (one vc) that would get me 6.3 ohm at the amp...correct?
If I wire the two vc's together in series (+ of one vc to - of other vc) and wire one channel of the amp to either of the two vc's that would get me 12.6 ohm...correct?
If I wire the two vc's together in parallel (+/- of one vc to +/- of other vc) and wire one channel of the amplifier to either of the two vc's that would get me 3.15 ohm...correct?
And I don't know why, but I have myself convinced that I read somewhere the Dipole 15's shouldn't be operated on just a single vc. Could that be possible?
Old 25th March 2015, 01:46 PM   #2
More than just the impedance changes depending on how they are wired.
Look here question about DVC drivers T/S parameters [Archive] - Techtalk Speaker Building, Audio, Video Discussion Forum
And here AE Speakers Dipole 15 or LO15 ? Need advice
And also here Acoustic Elegance • View topic - RE: Dipole 15 Specs. & 8ohms
Hopefully someone with much greater knowledge than myself will chime in.
Best of luck,
Dave
Old 26th March 2015, 03:34 AM   #3
Thank you for those links...some very good info there!
AE Speakers Dipole 15 or LO15 ? Need advice superlian Multi-Way 73 21st March 2015 08:45 AM
AE Dipole 12 Richidoo Swap Meet 1 26th March 2011 03:21 PM
DVC Wiring Question 69stingray Multi-Way 3 6th April 2007 12:42 PM
DVC wiring questions.. JRace Subwoofers 6 3rd March 2006 07:40 AM
wiring a sub in parellel with DVC Hat-Rack Subwoofers 4 8th March 2002 12:15 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
