Measure onJBL123 - diyAudio
Old 1st March 2015, 07:33 PM   #1
Liliya is online now Liliya  Norway
Default Measure onJBL123
I have two JBL123A. I hve measured this units with Dayton V2. Every measuring is pretty close to what I can read in the papers from JBL except from Q(ms).
My readings are 1.683 and 1.389. JBL paper says 8.5. Is there anything wrong with my speakers.
Q(es) is 0.589/0.579 and Q(ts) is 0.414/0.431
I hope for comments.
Eivind Stillingen
Old 2nd March 2015, 07:27 AM   #2
bitSmasher's Avatar
How old are they?
Old 2nd March 2015, 07:50 AM   #3
I do not know their excact age. They have the grey cone, so I think they are real vintage.
Eivind Stillingen
Old 2nd March 2015, 09:12 AM   #4
CLS is offline CLS  Taiwan
What are other parameters? fs for example.
Are the suspensions obviously stiffened?
And I guess the Alnico magnets are probably demagnetized somewhat.
Old 2nd March 2015, 09:26 AM   #5
With Dayton V2 I measured Fs= 26.92 on both elements.
What can be done to to this?
Old 2nd March 2015, 03:46 PM   #6
GM is online now GM  United States
GM's Avatar
To best answer your question, I need all of the measured data because right now your averaged numbers don't 'compute' based on your statement that 'Every measuring is pretty close to what I can read in the papers from JBL except from Q(ms).'.
Note that JBL's published specs don't 'compute' either, so I'm trying to figure out which is the most correct set of specs overall.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 2nd March 2015, 07:45 PM   #7
Default JBL123A/2213(H)
I got a third JBL123A to day and here are the measure from all three
File Type: zip 6 - JBL123A NR.3 Measuring V(as)med 90 gram.zip (696.1 KB, 2 views)
Old 5th March 2015, 12:38 AM   #8
GM's Avatar
Assuming you mean, can it be corrected? Yes, they can be drained and re-magnetized if Qes has gone up enough to justify the cost.
GM
Old 5th March 2015, 12:47 AM   #9
GM's Avatar
Cool! Thanks! I'll go through them as time permits.
GM
Old 6th March 2015, 10:55 AM   #10
Lets take the results from one of my 123A speakers an put it in to this formula:
1/q(ts)= 1/Q(es)+1/Q/ms)
1/0.414 =1/0.589 + 1/Q(ms)
2.41 = 1.69 +1/Q(ms)
2.41-1.69=1/Q(ms)
1/Q(ms) = 0.72
Q(ms) = 1/0.72 = 1.388
Measured value for this unit: 1.389
So, if all the other parameters I have measured the measured Q(ms) is correct.
HOW DO I BRING BACK THE UNIT TO THE CORRECT Q(ms)= 8
I have earlier red that the magnet of this type can loses their Q(ms) value over the years.
Eivind Stillingen
How to measure one is getting too old for this? AndrewT Everything Else 44 28th July 2014 06:31 PM
How do I measure amps? doug20 Solid State 4 27th July 2009 02:57 AM
How to measure T/S of tweeter? darw82 Full Range 3 23rd November 2007 08:58 AM
Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? percy Multi-Way 0 12th March 2006 09:18 PM
How do you measure ripple on the B+? porkchop61 Tubes / Valves 9 4th October 2005 11:51 PM
Copyright 1999-2017 diyAudio
