Behringer 15p200a3 cone removal - diyAudio
Old 14th February 2015, 10:36 AM   #1
djduck is offline djduck  Estonia
Default Behringer 15p200a3 cone removal
Hello!
I picked up a free Behringer 15p200a3 woofer for only 4.10 shipping. It had just stopped working at random, without any overload or anything. Measuring from terminals shows no continuity and no resistance. No scratching or burnt smell from voice coil. Guy who gave it to me thought that voice coil connection wires might have come off inside the coil.
What I want to do is take it apart and see if I can repair the coil. But Behringer has used some super heavy duty black glue to hold the cloth surround to the basket and I can't seem to get it off. I tried dissolving it with acetone but it only softens up slightly and I feel as tho I will rip the surround while pulling it off.
Any other good solvents for this type of glue?
If I can get it to work, I want to try building my first ever folded horn with it
Old 15th February 2015, 02:22 PM   #2
freddi is offline freddi  United States
freddi's Avatar
do you think you can get to the area where something has disconnected by removing the dust cap? - I've no idea what's needed to loosen the cement used in that area. Do the tinsel leads attach to a visible place on the cone or are they woven in the spider?
Old 15th February 2015, 02:29 PM   #3
The dust cap had already been removed, no access.
But that doesn't matter anymore. I got the cone off but the spider was stuck even worse, so I thought f**k it and cut it off with an exacto knife. Well, as it rurns out I didn't make a wrong move, as the voice coil has a nice burnt spot on it and it's obvious that it had gotten hot all around. I kept the cone and surround, dumped the coil and spider. Now I'm on the lookout for a new set of those, or even a complete re-cone kit.
Old 15th February 2015, 02:50 PM   #4
There are no recone kits for these Behringer speakers unfortunately, so short of making some generic parts work you now have a nice paperweight.
Old 15th February 2015, 02:53 PM   #5
Dang. Thought so. But there are some woofers that are similiar, such as the Eminence Delta 15A, that might work. If not, then I have a nice lampshade from the basket
FS: Behringer B2031A Pair (Some say they beat Orion!) and Behringer DCX2496 bmwparts Swap Meet 10 17th December 2014 01:58 PM
cone removal back Subwoofers 16 5th April 2014 01:04 AM
Which glue to fix cone (Very tiny tear in cone) JdAo Multi-Way 8 16th September 2012 06:00 AM
Increase cone mass to rid cone resonance; worth it? bikinpunk Multi-Way 6 30th July 2010 05:08 PM
Repair Vifa D6.8 Plastic Speaker Cone with hole in cone excetara2 Multi-Way 0 30th August 2009 02:32 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
